Optix/RTX support
Re: Optix/RTX support
I have the game drivers, no Optix or CUDA SDK, and Optix is working fine here on Windows.
I had a pre-450 driver until today. Could it be that it doesn't use optix because I had already compiled the OCL-kernel with the old driver? Wasn't it so that each LuxCore installation now only compiles once?
I just found out that I had to enable CUDA/OPTIX in the addon preferences :!:
Now it seems to work (and still on Game-Ready driver as well, just to conform with BYOB's statement).
juangea
Post by juangea »
It includes Optix Support, we don't use Studio version at all, so it must include the support.
Odilkhan Yakubov
Post by Odilkhan Yakubov »
Im also selected Optix on blender user pref system and also selected cuda on lux addon too. Optix works but there isnt optix denoiser option in luxcore latest build. Am i wrong?
acasta69
Post by acasta69 »
Since our Optix/RTX implementation needs Cuda 11, should we update the nvrtc and nvrtc-builtins libraries to v11?
At the moment we are distributing v10.1, at least in Windows packages.
I was testing if the GTX970 + driver v451.67 is working with Optix and had some strange behaviour (i.e. LuxCoreUI suddenly exiting without error messages). I was wondering if that could be the cause.
acasta69 wrote: Sat Aug 01, 2020 11:57 am Since our Optix/RTX implementation needs Cuda 11, should we update the nvrtc and nvrtc-builtins libraries to v11?
You can run CUDA 10 PTX on CUDA 11 but not CUDA 11 PTX on CUDA 10 so using an older compiler (NVRTC) is not a problem but a newer requires the very latest drivers.
LuxCore doesn't need CUDA 11 (or CUDA 10 for what it matters) and Optix doesn't use our NVRTC so we can use whatever version we want.
May be, we will have to use CUDA 11 NVRTC with the next generation of NVIDIA GPUs but, for the moment, it is not required.
acasta69
Post by acasta69 »
I keep getting LuxCoreUI crash when rendering the LuxMark-Hotel scene on the GTX 970: it exits without specific messages when the render is about to start. Here is the output:
F:\Ale\Devel\LuxCoreRender\LuxCoreTestScenes>C:\Users\Alessandro\Desktop\luxcorerender-latest-win64\luxcoreui.exe scenes\LuxMark-Hotel\render.cfg
LuxCoreUI v2.5alpha0 (LuxCore demo: http://www.luxcorerender.org)
[LuxCore][0.000] Configuration:
[LuxCore][0.000]   opencl.platform.index = "-1"
[LuxCore][0.000]   opencl.cpu.use = "0"
[LuxCore][0.000]   opencl.gpu.use = "1"
[LuxCore][0.000]   opencl.devices.select = "01"
[LuxCore][0.000]   opencl.native.threads.count = "0"
[LuxCore][0.000]   scene.epsilon.min = "9.99999972e-10"
[LuxCore][0.000]   scene.epsilon.max = "0.100000001"
[LuxCore][0.000]   renderengine.type = "PATHOCL"
[LuxCore][0.000]   accelerator.instances.enable = "1"
[LuxCore][0.000]   path.maxdepth = "6"
[LuxCore][0.000]   path.clamping.radiance.maxvalue = "32000.0"
[LuxCore][0.000]   biaspath.clamping.radiance.maxvalue = "32000.0"
[LuxCore][0.000]   lightstrategy.type = "UNIFORM"
[LuxCore][0.000]   film.width = "1024"
[LuxCore][0.000]   film.height = "576"
[LuxCore][0.000]   sampler.type = "SOBOL"
[LuxCore][0.000]   film.opencl.enable = "0"
[LuxCore][0.000]   film.filter.type = "GAUSSIAN"
[LuxCore][0.000]   film.filter.xwidth = "2"
[LuxCore][0.000]   film.filter.ywidth = "2"
[LuxCore][0.000]   film.imagepipeline.0.type = "TONEMAP_LINEAR"
[LuxCore][0.000]   film.imagepipeline.0.scale = "0.000776737288"
[LuxCore][0.000]   film.imagepipeline.1.type = "GAMMA_CORRECTION"
[LuxCore][0.000]   film.imagepipeline.1.value = "2.20000005"
[LuxCore][0.000]   scene.file = "scene.scn"
[LuxCore][0.000]   periodicsave.film.outputs.period = "600"
[LuxCore][0.000]   batch.haltspp = "400"
[LuxCore][0.000] File Name Resolver Configuration:
[LuxCore][0.000]   .
[LuxCore][0.000]   scenes/LuxMark-Hotel
[SDL][0.000] Reading scene: scenes/LuxMark-Hotel/scene.scn
[SDL][0.015] Texture definition: texture-0x7f9fb27f3290
[SDL][0.015] Texture definition: texture-0x7f9fa03399b0
[SDL][0.015] Texture definition: texture-0x7f9f9f815310
[SDL][0.015] Texture definition: texture-0x7f9fb29d0010
[SDL][0.015] Reading texture map: scenes/LuxMark-Hotel/imagemap-00000.exr
[SDL][0.312] Material definition: material-0x7f9fa03396a0
[SDL][0.328] Camera type: perspective
[SDL][0.328] Camera position: Point[4.03518, -5.64324, 1.16999]
[SDL][0.328] Camera target: Point[3.46807, -4.81972, 1.15577]
[SDL][0.328] Camera clipping plane disabled
[SDL][0.812] Scene objects count: 496
[SDL][0.812] Light definition: light-0x7f9fa0339bd0
[SDL][0.812] Light definition: light-0x7f9fa033a770
[SDL][0.984] Camera type: perspective
[SDL][0.984] Camera position: Point[4.03518, -5.64324, 1.16999]
[SDL][0.984] Camera target: Point[3.46807, -4.81972, 1.15577]
[SDL][0.984] Camera clipping plane disabled
Film size adjusted: 1024x576 (Frame buffer size: 1024x576)
RenderConfig has cached kernels: True
[LuxCore][1.000] Film resolution: 1024x576
[SDL][1.000] Film output definition: RGB_IMAGEPIPELINE [image.png]
[SDL][1.000] Image pipeline: film.imagepipeline
[SDL][1.000] Image pipeline step 0: TONEMAP_LINEAR
[SDL][1.000] Image pipeline step 1: GAMMA_CORRECTION
[LuxRays][1.000] OpenCL support: enabled
[LuxRays][1.015] OpenCL Platform 0: NVIDIA CUDA
[LuxRays][1.015] CUDA support: enabled
[LuxRays][1.015] CUDA support: available
[LuxRays][1.015] CUDA driver version: 11.0
[LuxRays][1.015] CUDA device count: 1
[LuxRays][1.015] Optix support: available
[LuxRays][1.015] Device 0 name: Native
[LuxRays][1.015] Device 0 type: NATIVE_THREAD
[LuxRays][1.015] Device 0 compute units: 1
[LuxRays][1.015] Device 0 preferred float vector width: 4
[LuxRays][1.015] Device 0 max allocable memory: 17592186044415MBytes
[LuxRays][1.015] Device 0 max allocable memory block size: 17592186044415MBytes
[LuxRays][1.015] Device 0 has out of core memory support: 0
[LuxRays][1.015] Device 1 name: GeForce GTX 970
[LuxRays][1.015] Device 1 type: OPENCL_GPU
[LuxRays][1.015] Device 1 compute units: 13
[LuxRays][1.015] Device 1 preferred float vector width: 1
[LuxRays][1.015] Device 1 max allocable memory: 4096MBytes
[LuxRays][1.015] Device 1 max allocable memory block size: 1024MBytes
[LuxRays][1.015] Device 1 has out of core memory support: 0
[LuxRays][1.015] Device 2 name: GeForce GTX 970
[LuxRays][1.015] Device 2 type: CUDA_GPU
[LuxRays][1.015] Device 2 compute units: 128
[LuxRays][1.015] Device 2 preferred float vector width: 1
[LuxRays][1.015] Device 2 max allocable memory: 4096MBytes
[LuxRays][1.015] Device 2 max allocable memory block size: 17592186044415MBytes
[LuxRays][1.015] Device 2 has out of core memory support: 1
[LuxRays][1.015] Creating 1 intersection device(s)
[LuxRays][1.015] Allocating intersection device 0: GeForce GTX 970 (Type = CUDA_GPU)
[LuxRays][1.078] [Optix][4][KNOBS] All knobs on default.
[LuxRays][1.125] [Optix][4][DISK CACHE] Opened database: "C:\Users\Alessandro\AppData\Local\NVIDIA\OptixCache\cache7.db"
[LuxRays][1.125] [Optix][4][DISK CACHE]     Cache data size: "17.3 KiB"
[LuxCore][1.125] CUDA devices used:
[LuxCore][1.125] [GeForce GTX 970 CUDAIntersect]
[LuxCore][1.125] OpenCL devices used:
[LuxCore][1.125] Native devices used: 0
[LuxCore][1.125] Configuring 1 OpenCL render threads
[LuxCore][1.125] Configuring 0 native render threads
[LuxRays][1.125] Preprocessing DataSet
[LuxRays][1.125] Total vertex count: 3229390
[LuxRays][1.125] Total triangle count: 4973406
[LuxRays][1.125] Preprocessing DataSet done
[LuxRays][1.125] Adding DataSet accelerator: OPTIX
[LuxRays][1.125] Building Optix accelerator
[LuxRays][1.469] Optix accelerator leafs: 496
[LuxRays][1.469] OptixAccel total build time: 343ms
[LuxRays][1.469] [OptixAccel] Compiler options: -D LUXRAYS_OPENCL_KERNEL -D PARAM_RAY_EPSILON_MIN=1e-09f -D PARAM_RAY_EPSILON_MAX=0.1f -D LUXRAYS_CUDA_DEVICE -D LUXRAYS_OS_WINDOWS --use_fast_math
[LuxRays][1.469] [OptixAccel] Program cached
[LuxRays][1.469] [Optix][4][DISKCACHE] Cache hit for key: ptx-2547-keyd4ee84a65eb13d6eecc98490c7e715b1-sm_52-rtc0-drv451.67
[LuxRays][1.484] [Optix][4][COMPILE FEEDBACK] Info: Pipeline has 1 module(s), 3 entry function(s), 1 trace call(s), 0 continuation callable call(s), 0 direct callable call(s), 10 basic block(s) in entry functions, 95 instruction(s) in entry functions, 7 non-entry function(s), 42 basic block(s) in non-entry functions, 616 instruction(s) in non-entry functions
[LuxRays][1.484] Total Optix memory usage: 278237Kbytes
[LuxRays][1.484] Adding DataSet accelerator: EMBREE
[LuxRays][1.484] Total vertex count: 3229390
[LuxRays][1.484] Total triangle count: 4973406
[LuxRays][1.844] EmbreeAccel build time: 359ms
[LuxCore][1.844] [PathOCLRenderEngine] OpenCL task count: 131072
[LuxCore][1.844] [PathOCLBaseRenderEngine] OpenCL max. page memory size: 18014398509481983Kbytes
[LuxCore][1.844] Compile Geometry
[LuxCore][1.969] Scene geometry compilation time: 125ms
[LuxCore][1.969] Compile 256 Textures
[LuxCore][1.969] Texture evaluation ops count: 872
[LuxCore][1.969] Texture evaluation max. stack size: 11
[LuxCore][1.969] Textures compilation time: 0ms
[LuxCore][1.969] Compile 53 Materials
[LuxCore][1.969] Material evaluation ops count: 371
[LuxCore][1.969] Material evaluation max. stack size: 8
[LuxCore][1.969] Material compilation time: 0ms
[LuxCore][1.969] Compile Lights
[LuxCore][1.969] Lights compilation time: 0ms
[LuxCore][1.969] Compile ImageMaps
[LuxCore][2.031] Image maps page(s) count: 1
[LuxCore][2.031]  RGB channel page 0 size: 50176Kbytes
[LuxCore][2.031] Image maps compilation time: 61ms
[LuxCore][2.031] Always enabled OpenCL code:
[LuxCore][2.031] Compile Geometry
[LuxCore][2.062] Scene geometry compilation time: 31ms
[LuxCore][2.062] Compile 256 Textures
[LuxCore][2.062] Texture evaluation ops count: 872
[LuxCore][2.062] Texture evaluation max. stack size: 11
[LuxCore][2.062] Textures compilation time: 0ms
[LuxCore][2.062] Compile 53 Materials
[LuxCore][2.062] Material evaluation ops count: 371
[LuxCore][2.062] Material evaluation max. stack size: 8
[LuxCore][2.062] Material compilation time: 0ms
[LuxCore][2.062] Compile Lights
[LuxCore][2.062] Lights compilation time: 0ms
[LuxCore][2.062] Compile ImageMaps
[LuxCore][2.125] Image maps page(s) count: 1
[LuxCore][2.125]  RGB channel page 0 size: 50176Kbytes
[LuxCore][2.125] Image maps compilation time: 63ms
[LuxCore][2.125] Starting 1 OpenCL render threads
[LuxRays][2.140] [Device GeForce GTX 970 CUDAIntersect] RADIANCE_PER_PIXEL_NORMALIZEDs[0] buffer size: 9216Kbytes
[LuxRays][2.156] [Device GeForce GTX 970 CUDAIntersect] NOISE buffer size: 2304Kbytes
[LuxRays][2.156] [Device GeForce GTX 970 CUDAIntersect] RADIANCE_PER_PIXEL_NORMALIZEDs[0] buffer size: 9216Kbytes
[LuxRays][2.156] [Device GeForce GTX 970 CUDAIntersect] Camera buffer size: 5488bytes
[LuxRays][2.156] [Device GeForce GTX 970 CUDAIntersect] Normals buffer size: 16359Kbytes
[LuxRays][2.172] [Device GeForce GTX 970 CUDAIntersect] UVs buffer size: 8487Kbytes
[LuxRays][2.172] [Device GeForce GTX 970 CUDAIntersect] Triangle normals buffer size: 26930Kbytes
[LuxRays][2.172] [Device GeForce GTX 970 CUDAIntersect] Vertices buffer size: 16359Kbytes
[LuxRays][2.187] [Device GeForce GTX 970 CUDAIntersect] Triangles buffer size: 26930Kbytes
[LuxRays][2.187] [Device GeForce GTX 970 CUDAIntersect] Mesh description buffer size: 151Kbytes
[LuxRays][2.187] [Device GeForce GTX 970 CUDAIntersect] ImageMap descriptions buffer size: 608bytes
[LuxRays][2.187] [Device GeForce GTX 970 CUDAIntersect] ImageMaps buffer size: 50176Kbytes
[LuxRays][2.203] [Device GeForce GTX 970 CUDAIntersect] Textures buffer size: 74Kbytes
[LuxRays][2.203] [Device GeForce GTX 970 CUDAIntersect] Texture evaluation ops buffer size: 6976bytes
[LuxRays][2.203] [Device GeForce GTX 970 CUDAIntersect] Texture evaluation stacks buffer size: 5632Kbytes
[LuxRays][2.203] [Device GeForce GTX 970 CUDAIntersect] Materials buffer size: 11Kbytes
[LuxRays][2.203] [Device GeForce GTX 970 CUDAIntersect] Material evaluation ops buffer size: 4452bytes
[LuxRays][2.203] [Device GeForce GTX 970 CUDAIntersect] Material evaluation stacks buffer size: 4096Kbytes
[LuxRays][2.203] [Device GeForce GTX 970 CUDAIntersect] Scene objects buffer size: 11Kbytes
[LuxRays][2.203] [Device GeForce GTX 970 CUDAIntersect] Lights buffer size: 664bytes
[LuxRays][2.203] [Device GeForce GTX 970 CUDAIntersect] Env. light indices buffer size: 8bytes
[LuxRays][2.203] [Device GeForce GTX 970 CUDAIntersect] Light offsets (Part I) buffer size: 1984bytes
[LuxRays][2.203] [Device GeForce GTX 970 CUDAIntersect] Env. light distributions buffer size: 1028Kbytes
[LuxRays][2.203] [Device GeForce GTX 970 CUDAIntersect] LightsDistribution buffer size: 24bytes
[LuxRays][2.203] [Device GeForce GTX 970 CUDAIntersect] InfiniteLightSourcesDistribution buffer size: 24bytes
[LuxRays][2.203] [Device GeForce GTX 970 CUDAIntersect] Ray buffer size: 6144Kbytes
[LuxRays][2.203] [Device GeForce GTX 970 CUDAIntersect] RayHit buffer size: 2560Kbytes
[LuxRays][2.203] [Device GeForce GTX 970 CUDAIntersect] GPUTaskConfiguration buffer size: 288bytes
[LuxRays][2.203] [Device GeForce GTX 970 CUDAIntersect] GPUTask buffer size: 84992Kbytes
[LuxRays][2.219] [Device GeForce GTX 970 CUDAIntersect] GPUTaskDirectLight buffer size: 7680Kbytes
[LuxRays][2.219] [Device GeForce GTX 970 CUDAIntersect] GPUTaskState buffer size: 50176Kbytes
[LuxRays][2.219] [Device GeForce GTX 970 CUDAIntersect] GPUTask Stats buffer size: 512Kbytes
[LuxRays][2.219] [Device GeForce GTX 970 CUDAIntersect] SamplerSharedData buffer size: 2312Kbytes
[LuxCore][2.219] [PathOCLBaseRenderThread::0] Size of a Sample: 40bytes
[LuxRays][2.219] [Device GeForce GTX 970 CUDAIntersect] Sample buffer size: 5120Kbytes
[LuxCore][2.219] [PathOCLBaseRenderThread::0] Size of a SampleData: 8bytes
[LuxRays][2.219] [Device GeForce GTX 970 CUDAIntersect] SampleData buffer size: 1024Kbytes
[LuxCore][2.234] [PathOCLBaseRenderThread::0] Size of a SampleResult: 308bytes
[LuxRays][2.234] [Device GeForce GTX 970 CUDAIntersect] Sample buffer size: 39424Kbytes
[LuxRays][2.234] [Device GeForce GTX 970 CUDAIntersect] PathInfo buffer size: 13824Kbytes
[LuxRays][2.234] [Device GeForce GTX 970 CUDAIntersect] DirectLightVolumeInfo buffer size: 5632Kbytes
[LuxRays][2.234] [Device GeForce GTX 970 CUDAIntersect] Pixel Filter Distribution buffer size: 33Kbytes
[LuxCore][2.234] [PathOCLBaseRenderThread::0] Compiling kernels
[LuxRays][2.234] [PathOCL kernel] Compiler options: -D LUXRAYS_OPENCL_KERNEL -D SLG_OPENCL_KERNEL -D RENDER_ENGINE_PATHOCL -D PARAM_RAY_EPSILON_MIN=1e-09f -D PARAM_RAY_EPSILON_MAX=0.1f -D LUXRAYS_CUDA_DEVICE -D LUXRAYS_OS_WINDOWS --use_fast_math
[LuxRays][2.234] [PathOCL kernel] Compiling kernels
[LuxRays][2.281] [PathOCL kernel] Program cached
[LuxCore][2.281] [PathOCLBaseRenderThread::0] Compiling Film_Clear Kernel
[LuxCore][2.281] [PathOCLBaseRenderThread::0] Compiling InitSeed Kernel
[LuxCore][2.281] [PathOCLBaseRenderThread::0] Compiling Init Kernel
[LuxCore][2.281] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_RT_NEXT_VERTEX Kernel
[LuxCore][2.281] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_HIT_NOTHING Kernel
[LuxCore][2.281] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_HIT_OBJECT Kernel
[LuxCore][2.281] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_RT_DL Kernel
[LuxCore][2.281] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_DL_ILLUMINATE Kernel
[LuxCore][2.281] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_DL_SAMPLE_BSDF Kernel
[LuxCore][2.281] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_GENERATE_NEXT_VERTEX_RAY Kernel
[LuxCore][2.281] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_SPLAT_SAMPLE Kernel
[LuxCore][2.281] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_NEXT_SAMPLE Kernel
[LuxCore][2.281] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_GENERATE_CAMERA_RAY Kernel
[LuxCore][2.281] [PathOCLBaseRenderThread::0] AdvancePaths_MK_* workgroup size: 32
[LuxCore][2.281] [PathOCLBaseRenderThread::0] Kernels compilation time: 46ms
[LuxCore][2.281] Starting 0 native render threads
I think it might be related to Optix as other scenes, where Optix does not seem to be used, render ok.
This is the render.cfg I'm using for the LuxMark-Hotel scene:
render.cfg
(875 Bytes) Downloaded 1534 times
By the way: should Optix be used automatically if available? I was wondering why it is found when I render LuxMark-Hotel but not e.g. LuxMark-Mic. In both cases I use the CUDA_GPU, the only difference seems to me that I have disabled native threads for LuxMark-Hotel.
LuxMark-Hotel:
LuxMark-Mic:
[LuxRays][0.829] OpenCL support: enabled
[LuxRays][0.844] OpenCL Platform 0: NVIDIA CUDA
[LuxRays][0.844] CUDA support: enabled
[LuxRays][0.844] CUDA support: available
[LuxRays][0.844] CUDA driver version: 11.0
[LuxRays][0.844] CUDA device count: 1
[LuxRays][0.844] Device 0 name: Native
acasta69 wrote: Tue Aug 04, 2020 4:44 pm In both cases I use the CUDA_GPU, the only difference seems to me that I have disabled native threads for LuxMark-Hotel.
LuxMark-Hotel:
LuxMark-Mic:
Check the code: https://github.com/LuxCoreRender/LuxCor ... t.cpp#L115
It doesn't make sense, you must have or the "Optix support: available" or the "Optix support: not available" log print. The only explanation I can think is that you are not running the same executable (i.e. the second output is from v2.4) :?:
acasta69
Post by acasta69 »
Dade wrote: Tue Aug 04, 2020 7:00 pm The only explanation I can think is that you are not running the same executable (i.e. the second output is from v2.4) :?:
Ok, I'll double check this, thanks Dade.
