New Random/Sobol sampler progressive, cache-friendly and OoC modes
juangea
Re: New Random/Sobol sampler progressive, cache-friendly and OoC modes
Post by juangea »
B.Y.O.B should have a scene that will put your ram into it’s knees, it needs around 16Gb of ram.
It’s not converted to LuxCore, but it does not matter too much, it has a TON of instances, and some materials may work, so to test OOC it should be more than enough, also to test other things like instances performance and such things.
BTW it’s a commercial scene, please don’t share it except amongst you and B.Y.O.B.
@B.Y.O.B. If you don’t have it at hand speak to me on Discord and I’ll send it back to you again.
I have added support to the new sampling patterns and out of core to BlendLuxCore.
Dade, how can I calculate the samples (per pixel) per pass, taking into account the new settings? I'm not sure how the overlap works in detail.
I'd like to show the samples (per pixel) per pass to the user because it's important for halt conditions.
Screenshot from 2020-05-18 19-58-06.png (11.04 KiB) Viewed 8516 times
B.Y.O.B. wrote: Mon May 18, 2020 6:02 pm Dade, how can I calculate the samples (per pixel) per pass, taking into account the new settings? I'm not sure how the overlap works in detail.
If I remember correctly it is "sampler.sobol.supersampling * sampler.sobol.overlapping" for each pass.
Dade wrote: Mon May 18, 2020 6:58 pm If I remember correctly it is "sampler.sobol.supersampling * sampler.sobol.overlapping" for each pass.
That was my understanding as well, and when not using light tracing, it seems to be true indeed.
I guess the samples spent on light tracing are added to the sample count. I vaguely remember that you added separate statistics for eye and light traced samples, are they accessible somehow?
edit: found it:
stats.renderengine.pass.eye
stats.renderengine.pass.light
It might be good if we could specify an "eye pass" halt condition, instead of the current eye + light pass halt condition, to ensure that a pass covers the entire film plane.
without light tracing, overlap = 32, supersampilng = 16, 512 spp halt condition
with light tracing, overlap = 32, supersampilng = 16, 512 spp halt condition
Yes, it was discussed in another thread, we probably need an 2 halt conditions, one for eye and one for light samples otherwise you can have some problem when light tracing is enabled.
This mode is even slower (it renders about x * 32 samples per pixel instead of 1) to cover all the image and its main benefit is for OoC because most samples will reuse the same data cached from CPU ram.
I have sincerely some problem to test OoC rendering at the moment. First of all, I lack a test scene to put out of memory the 8GB of my GPU. So this topic may need some further investigation to check the results.
Any possibility to extend OOC capability to SSD drive. i've 32 gb of ram but i can barelly test OOC as most complexe enough scene i have fill up CPU RAM pretty quickly too. maybe 64 GB of ram will work but it isn't very common making the feature currently a bit a niche tool.
Sharlybg wrote: Tue Jun 30, 2020 7:16 pm Any possibility to extend OOC capability to SSD drive. i've 32 gb of ram but i can barelly test OOC as most complexe enough scene i have fill up CPU RAM pretty quickly too. maybe 64 GB of ram will work but it isn't very common making the feature currently a bit a niche tool.
It may already work with virtual memory swapped on SSD but it would be insanely slow.
