Path Space Regularization (aka the solution to SDS paths)
Re: Path Space Regularization (aka the solution to SDS paths)
Post by lacilaci » Wed Sep 11, 2019 10:04 am
Dade wrote:
Wed Sep 11, 2019 9:31 am
lacilaci wrote:
Tue Sep 10, 2019 1:19 pm
here's the scene I'm working with... Check it out pls, maybe I fucked up something somewhere..
It is a strange problems, it is like if Metropolis is "trapped" on flat surfaces. A smooth sphere seems hard to render and flat sphere produces this very strange result:
It is like Metropolis struggle to find all faces, it finds one once in a while. I'm trying to figure out why.
Great, I hope you find solution...
Another thing I wonder, would you get brighter underwater surface with hybrid glass? Or would it still be only limited to sds only?
here are few examples of pool water look that I cannot achieve right now no matter what
my underwater surface is always very dark unless I hide the waterbody from camera.
Post by lacilaci » Sun Sep 15, 2019 6:36 am
here's lighttracing threshold at 0.05
and here at 1
so the round objects will still look dark and wrong and won't get caustics but look how much greater contrast I get when I force lighttracing threshold to include all materials for lighttracing
provisory
Post by provisory » Sun Sep 15, 2019 7:35 am
+1
Light Tracing without limits! :)
Post by Dade » Sun Sep 15, 2019 12:18 pm
I have an idea...
Post by Sharlybg » Sun Sep 15, 2019 1:20 pm
I have an idea...
Ok guys we are not far to render disney Moana sea on a single thread.
Joke aside supra good news. :mrgreen:
Post by Dade » Sun Sep 15, 2019 2:07 pm
I have an idea...
It looks good, I can work on it:
It is the result of eye tracing (for most stuff) + light tracing (for caustics) + PhotonGI "SDS cache" (for SDS paths).
The under water is dark but it is the same for all other kind of renderings and I assume is a different type of problem.
To have an idea how it works, this is a 10 samples/pixel rendering:
The under water caustics looks good from the very beginning.
Post by lacilaci » Sun Sep 15, 2019 2:29 pm
they do look a bit blurry though. Can this be adjusted?
As for the dark underwater surface. Could it be an issue with glass shader rather than something else? Or maybe the shadow from pathtracing is taking over lighttracing?
Post by epilectrolytics » Sun Sep 15, 2019 2:36 pm
I have an idea...
Very interesting!
What is the difference in building "SDS-cache" from building caustic cache?
I'm asking because building caustic cache turned out to be so difficult that we needed periodic revolving and still it took very long.
Post by lacilaci » Sun Sep 15, 2019 2:39 pm
Dade you should also take a look at this scene with this new approach:
viewtopic.php?f=2&t=1416&start=10
PSR could make the nice sharp ring on the floor but normal lighttracing not... Would sdscache work there?
