Need a little help
Posted: Tue Mar 12, 2019 9:36 pm
by ajm
Running Linux Mint 19.1 and had to roll some stuff back to the supported kernel and drivers, but in doing so I lost something and now when I try to render in Lux I get a clBuildProgram error and a never ending string of warnings in the terminal. Any idea of what I nuked? Some libopencl or something?
Re: Need a little help
Posted: Tue Mar 12, 2019 11:44 pm
Yes, it is an OpenCL related error, so check if your OpenCL installation is working, for instance by running clinfo or LuxMark. Check to have NVIDIA/AMD GPU driver installed.
Posted: Wed Mar 13, 2019 11:36 am
by ajm
This is the output but it looks like things are okay to me, unless there is an issue with the null device type.
Number of platforms                               1
  Platform Name                                   NVIDIA CUDA
  Platform Vendor                                 NVIDIA Corporation
  Platform Version                                OpenCL 1.2 CUDA 9.1.84
  Platform Profile                                FULL_PROFILE
  Platform Extensions                             cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_copy_opts cl_nv_create_buffer
  Platform Extensions function suffix             NV
Number of devices                                 1
  Device Name                                     GeForce GTX 970
  Device Vendor                                   NVIDIA Corporation
  Device Vendor ID                                0x10de
  Device Version                                  OpenCL 1.2 CUDA
  Driver Version                                  390.116
  Device OpenCL C Version                         OpenCL C 1.2
  Device Type                                     GPU
  Device Topology (NV)                            PCI-E, 0b:00.0
  Device Profile                                  FULL_PROFILE
  Device Available                                Yes
  Compiler Available                              Yes
  Linker Available                                Yes
  Max compute units                               13
  Max clock frequency                             1316MHz
  Compute Capability (NV)                         5.2
  Device Partition                                (core)
    Max number of sub-devices                     1
    Supported partition types                     None
  Max work item dimensions                        3
  Max work item sizes                             1024x1024x64
  Max work group size                             1024
  Preferred work group size multiple              32
  Warp size (NV)                                  32
  Preferred / native vector sizes
    char                                                 1 / 1
    short                                                1 / 1
    int                                                  1 / 1
    long                                                 1 / 1
    half                                                 0 / 0        (n/a)
    float                                                1 / 1
    double                                               1 / 1        (cl_khr_fp64)
  Half-precision Floating-point support           (n/a)
  Single-precision Floating-point support         (core)
    Denormals                                     Yes
    Infinity and NANs                             Yes
    Round to nearest                              Yes
    Round to zero                                 Yes
    Round to infinity                             Yes
    IEEE754-2008 fused multiply-add               Yes
    Support is emulated in software               No
    Correctly-rounded divide and sqrt operations  Yes
  Double-precision Floating-point support         (cl_khr_fp64)
    Denormals                                     Yes
    Round to zero                                 Yes
  Address bits                                    64, Little-Endian
  Global memory size                              4230545408 (3.94GiB)
  Error Correction support                        No
  Max memory allocation                           1057636352 (1009MiB)
  Unified memory for Host and Device              No
  Integrated memory (NV)                          No
  Minimum alignment for any data type             128 bytes
  Alignment of base address                       4096 bits (512 bytes)
  Global Memory cache type                        Read/Write
  Global Memory cache size                        212992 (208KiB)
  Global Memory cache line size                   128 bytes
  Image support                                   Yes
    Max number of samplers per kernel             32
    Max size for 1D images from buffer            134217728 pixels
    Max 1D or 2D image array size                 2048 images
    Max 2D image size                             16384x16384 pixels
    Max 3D image size                             4096x4096x4096 pixels
    Max number of read image args                 256
    Max number of write image args                16
  Local memory type                               Local
  Local memory size                               49152 (48KiB)
  Registers per block (NV)                        65536
  Max number of constant args                     9
  Max constant buffer size                        65536 (64KiB)
  Max size of kernel argument                     4352 (4.25KiB)
  Queue properties
    Out-of-order execution                        Yes
    Profiling                                     Yes
  Prefer user sync for interop                    No
  Profiling timer resolution                      1000ns
  Execution capabilities
    Run OpenCL kernels                            Yes
    Run native kernels                            No
    Kernel execution timeout (NV)                 Yes
  Concurrent copy and kernel execution (NV)       Yes
    Number of async copy engines                  2
  printf() buffer size                            1048576 (1024KiB)
  Built-in kernels
  Device Extensions                               cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_copy_opts cl_nv_create_buffer
NULL platform behavior
  clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...)  NVIDIA CUDA
  clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...)   Success [NV]
  clCreateContext(NULL, ...) [default]            Success [NV]
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_DEFAULT)  No platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_CPU)  No devices found in platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU)  No platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_ACCELERATOR)  No devices found in platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM)  Invalid device type for platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL)  No platform
ICD loader properties
  ICD loader Name                                 OpenCL ICD Loader
  ICD loader Vendor                               OCL Icd free software
  ICD loader Version                              2.2.11
  ICD loader Profile                              OpenCL 2.1
Or should I have the mesa drivers installed?
Posted: Wed Mar 13, 2019 11:55 am
It looks right. Does LuxMark work ?
Nope.
Can you post an example of the terminal output ?
Posted: Wed Mar 13, 2019 5:50 pm
by ajm
I would, but I used Timeshift and restored my system. Now I'll just have to watch for the dreadded random reboot, however everything works now. The output as I remember was a neverending stream of warnings that referred to a path that included cmake, I doubt that helps much. Seemed like it was during the kernel compiling phase.
Thanks for trying to help, Dade. Great advacements by the team, by the way.
