Shader view vs rendered image
Posted: Tue Mar 12, 2019 6:58 am
by tayo6
I was trying to make procedural planets with luxcore, issue was, i could see the effect come to live in the shader box, but
i don't see the effect in both preview port and rendered image.
Re: Shader view vs rendered image
Posted: Tue Mar 12, 2019 7:43 am
Can you upload the scene?
Posted: Tue Mar 12, 2019 9:29 am
by tayo6
B.Y.O.B. wrote: ↑Tue Mar 12, 2019 7:43 am
Posted: Tue Mar 12, 2019 9:31 am
by tayo6
When I increased the noise size and distortion in the noise node, the effect became visible, but noise textures were stretched
Posted: Tue Mar 12, 2019 9:49 am
tayo6 wrote: ↑Tue Mar 12, 2019 9:31 am
It sounds like a scale problem, the size of the sphere is 0.1m, what is the scale of the cube ? You can adjust the 3D mapping (first node at left) scale and the preview sphere size (below the sphere input box) to match your cube.
Posted: Tue Mar 12, 2019 11:21 am
by tayo6
Dade wrote: ↑Tue Mar 12, 2019 9:49 am
I adjusted the sphere size to the same size as the cube, both were 1.00 . Then I moved to the 3d mapping node, changed the size to both 1.00 and 0.01, yet I did get the desired result. I still didn't get it.
Posted: Tue Mar 12, 2019 12:15 pm
The "sphere size" is the diameter of the preview sphere, not the radius.
The default cube is 2m in diameter, not 1m.
So set the sphere size to 2 and it should work.
Posted: Tue Mar 12, 2019 12:34 pm
by tayo6
B.Y.O.B. wrote: ↑Tue Mar 12, 2019 12:15 pm
Thank you, someone already helped me out. I used sphere 5.00 on the preview, which matched with the size of the rendered image. I learnt something new today. And I have to admit just like u told me last month, luxrender is easy to use
Posted: Tue Mar 12, 2019 8:11 pm
by tayo6
Thanks, the issue was the sphere size.
