Smoke color
Rivental1
Smoke color
Post by Rivental1 » Fri Mar 08, 2019 5:41 pm
Hello!!!
I can't understand how change the color of smoke.
When i change color of absorption it changed around the emmitter.
2) Can i to add only glossy to volume material (without diffuse and translucency)?
Thank you!
Re: Smoke color
Post by B.Y.O.B. » Fri Mar 08, 2019 11:51 pm
Here is an example scene that shows how to set up the nodes for colored smoke:
viewtopic.php?f=2&t=737#p7657
also this might help, although it's a bit older: viewtopic.php?f=5&t=9&p=2918&hilit=smoke+color#p2918
Rivental1
Re: Smoke color
Post by Rivental1 » Sat Mar 09, 2019 7:49 am
I saw this setup and.... Maybe i am stuped but anyway cannot understand where color choosed
In cycles you just click to the absorption color (in color picker) and that all.
But in this setup we pluged other node to the absorption color (so we have not color picker).
Sory, if my english no perfect)
Re: Smoke color
Post by B.Y.O.B. » Sat Mar 09, 2019 9:37 am
Ah, sorry, in this setup the color comes from the smoke simulation (in the emitter settings) and is baked into the smoke.
This one should work for you:
The absorption depth controls how strong/saturated the color is (lower depth = more saturation).
Rivental1
Re: Smoke color
Post by Rivental1 » Sat Mar 09, 2019 12:46 pm
Thanks a lot!!! It is even more simple than cycles)
