Page 2 of 4
Re: wrong light groups with OpenCL
Posted: Tue Mar 05, 2019 5:43 pm
by pixel_peeper
update:
I downloaded
this buid and the bug seems fixed, thank you!
the only thing that doesn't work properly with OpenCL is this one, some lights are darker compared to other identical. I don't know how to explain in a better way but if you try to render this scene with OpenCL and CPU and check the passes you will notice it.
pixel_peeper wrote: ↑Tue Mar 05, 2019 9:37 am
Ok, if I disable clamp everything works fine on the scene I uploaded in this thread. But with my project scene the strange behaviour of some emitter that remains dark or with fewer samples is still present.
Here there is a simplified version of my project scene, the fewer samples issue in some random instance could be seen more clearly in
Col-R and
Col-B Render Layer.
https://ufile.io/huo7v
If anyone has also any tip on how to reduce render time (and fireflies) is much appreciated
again, thanks for the fast support!!
Posted: Tue Mar 05, 2019 8:42 pm
If you follow the workflow describe here you should not have problem with to long render time :
https://www.google.com/url?sa=t&source= ... m8ez2zTVkl
Also not that the more light group you have slower will be your performance.if possible try to use PGI cache.
Posted: Tue Mar 05, 2019 9:41 pm
by pixel_peeper
I need to reproduce a very realistic array of SMD LED, many many lights that are passing through a translucent material, I know that's a very difficult scene for a ray tracer. But I think that I will change the whole approach using a mix of Cycles, LuxCore and some compositing trick, I Just need to figure out how to achieve the desired result.
Posted: Tue Mar 05, 2019 11:22 pm
If each light only illuminates a small area, DLSC (direct light sampling cache) could also be interesting for you. It is available in the light strategy dropdown.
viewtopic.php?f=5&t=430
viewtopic.php?f=5&t=675
Posted: Wed Mar 06, 2019 8:57 am
pixel_peeper wrote: ↑Tue Mar 05, 2019 9:41 pm
Can you post a picture of the kind of image you want to achieve ?
Posted: Wed Mar 06, 2019 9:35 am
by pixel_peeper
I've tried but I can't get a significant improvement (and I noticed a random color shifting in some lights), I'm sorry that I can't investigate more this function but since I'm a bit hurry I need to finish this render in other ways. Thank you!
PS: just for the benefit of the software and the community please try to verifiy if this is a real bug or just a wrong setting due to my low experience with LuxCore, thank you! Here the post I'm referring to:
viewtopic.php?p=10983#p10983
Posted: Wed Mar 06, 2019 9:42 am
by pixel_peeper
Sharlybg wrote: ↑Wed Mar 06, 2019 8:57 am
Yep! Like this, but with more detail on the LEDs that change their intensity during the animation, so you can clearly see the diode wich increase its brightness.
Posted: Wed Mar 06, 2019 4:44 pm
pixel_peeper wrote: ↑Wed Mar 06, 2019 9:42 am
Instead of light groups you can change the intensity of your material emiitting light.
Set a key for intensity and animate the value.
The simplest shape for the LED plane can be a triangle. This reduces number of faces emitting light to one.
If you have circles the number of lights depends on the the points per circumstance.
Posted: Wed Mar 06, 2019 4:52 pm
by pixel_peeper
FarbigeWelt wrote: ↑Wed Mar 06, 2019 4:44 pm
Unfortunately Blender itself doesn't allow this
https://github.com/LuxCoreRender/BlendL ... issues/167
My LEDs needs to be very similar to these ones so I have a quite accurate lowpoly model, now I'm getting the desired result through a mix of Lux, Cycles end some compositing.
Posted: Wed Mar 06, 2019 5:27 pm
pixel_peeper wrote: ↑Tue Mar 05, 2019 5:43 pm
I can reproduce this at the 128 samples you set in the file, even with OpenCL CPU device (to eliminate possible driver issues). There might be a bug in the OpenCL code.
Have you tried higher sample numbers (something like 1000)?
