Building errors in Win10
Fox
Post by Fox » Sat Mar 02, 2019 5:21 pm
What is going on in below
       "D:\CP\luxcorerender\WindowsCompile\Build_CMake\LuxCore\LuxRays.sln" (default target) (1) ->
       "D:\CP\luxcorerender\WindowsCompile\Build_CMake\LuxCore\samples\luxcoreui\deps\glfw-3.1.1\src\glfw.vcxproj" (def
       ault target) (3) ->
       (Lib target) ->
         LINK : warning LNK4044: unrecognized option '/INCREMENTAL:NO'; ignored [D:\CP\luxcorerender\WindowsCompile\Bui
       ld_CMake\LuxCore\samples\luxcoreui\deps\glfw-3.1.1\src\glfw.vcxproj]
       "D:\CP\luxcorerender\WindowsCompile\Build_CMake\LuxCore\src\slg\bcd.vcxproj" (default target) (2) ->
       ld_CMake\LuxCore\src\slg\bcd.vcxproj]
       "D:\CP\luxcorerender\WindowsCompile\Build_CMake\LuxCore\src\slg\slg-kernels.vcxproj" (default target) (10) ->
       ld_CMake\LuxCore\src\slg\slg-kernels.vcxproj]
       "D:\CP\luxcorerender\WindowsCompile\Build_CMake\LuxCore\src\slg\openvdb.vcxproj" (default target) (8) ->
       ld_CMake\LuxCore\src\slg\openvdb.vcxproj]
       "D:\CP\luxcorerender\WindowsCompile\Build_CMake\LuxCore\src\luxcore\luxcore.vcxproj" (default target) (7) ->
       ld_CMake\LuxCore\src\luxcore\luxcore.vcxproj]
       "D:\CP\luxcorerender\WindowsCompile\Build_CMake\LuxCore\src\luxrays\luxrays.vcxproj" (default target) (5) ->
       ld_CMake\LuxCore\src\luxrays\luxrays.vcxproj]
       "D:\CP\luxcorerender\WindowsCompile\Build_CMake\LuxCore\src\slg\slg-film.vcxproj" (default target) (9) ->
       ld_CMake\LuxCore\src\slg\slg-film.vcxproj]
       "D:\CP\luxcorerender\WindowsCompile\Build_CMake\LuxCore\src\slg\slg-core.vcxproj" (default target) (6) ->
       ld_CMake\LuxCore\src\slg\slg-core.vcxproj]
       "D:\CP\luxcorerender\WindowsCompile\Build_CMake\LuxCore\samples\luxcorescenedemo\luxcorescenedemo.vcxproj.metapr
       oj" (default target) (15) ->
       "D:\CP\luxcorerender\WindowsCompile\Build_CMake\LuxCore\samples\luxcorescenedemo\luxcorescenedemo.vcxproj" (defa
       ult target) (22) ->
       (Link target) ->
         D:\CP\luxcorerender\WindowsCompileDeps\x64\Release\lib\embree3.lib : fatal error LNK1107: invalid or corrupt f
       ile: cannot read at 0x82 [D:\CP\luxcorerender\WindowsCompile\Build_CMake\LuxCore\samples\luxcorescenedemo\luxcor
       escenedemo.vcxproj]
       "D:\CP\luxcorerender\WindowsCompile\Build_CMake\LuxCore\samples\luxcoredemo\luxcoredemo.vcxproj.metaproj" (defau
       lt target) (13) ->
       "D:\CP\luxcorerender\WindowsCompile\Build_CMake\LuxCore\samples\luxcoredemo\luxcoredemo.vcxproj" (default target
       ) (21) ->
       ile: cannot read at 0x82 [D:\CP\luxcorerender\WindowsCompile\Build_CMake\LuxCore\samples\luxcoredemo\luxcoredemo
       .vcxproj]
       "D:\CP\luxcorerender\WindowsCompile\Build_CMake\LuxCore\samples\luxcoreconsole\luxcoreconsole.vcxproj.metaproj"
       (default target) (12) ->
       "D:\CP\luxcorerender\WindowsCompile\Build_CMake\LuxCore\samples\luxcoreconsole\luxcoreconsole.vcxproj" (default
       target) (20) ->
       ile: cannot read at 0x82 [D:\CP\luxcorerender\WindowsCompile\Build_CMake\LuxCore\samples\luxcoreconsole\luxcorec
       onsole.vcxproj]
       "D:\CP\luxcorerender\WindowsCompile\Build_CMake\LuxCore\tests\benchsimple\benchsimple.vcxproj.metaproj" (default
        target) (11) ->
       "D:\CP\luxcorerender\WindowsCompile\Build_CMake\LuxCore\tests\benchsimple\benchsimple.vcxproj" (default target)
       (19) ->
       ile: cannot read at 0x82 [D:\CP\luxcorerender\WindowsCompile\Build_CMake\LuxCore\tests\benchsimple\benchsimple.v
       cxproj]
       "D:\CP\luxcorerender\WindowsCompile\Build_CMake\LuxCore\tests\luxcoreimplserializationdemo\luxcoreimplserializat
       iondemo.vcxproj.metaproj" (default target) (14) ->
       iondemo.vcxproj" (default target) (24) ->
       ile: cannot read at 0x82 [D:\CP\luxcorerender\WindowsCompile\Build_CMake\LuxCore\tests\luxcoreimplserializationd
       emo\luxcoreimplserializationdemo.vcxproj]
       "D:\CP\luxcorerender\WindowsCompile\Build_CMake\LuxCore\samples\luxcoreui\luxcoreui.vcxproj.metaproj" (default t
       arget) (16) ->
       "D:\CP\luxcorerender\WindowsCompile\Build_CMake\LuxCore\samples\luxcoreui\luxcoreui.vcxproj" (default target) (2
       3) ->
       ile: cannot read at 0x82 [D:\CP\luxcorerender\WindowsCompile\Build_CMake\LuxCore\samples\luxcoreui\luxcoreui.vcx
       proj]
       "D:\CP\luxcorerender\WindowsCompile\Build_CMake\LuxCore\src\luxcore\pyluxcore.vcxproj.metaproj" (default target)
        (17) ->
       "D:\CP\luxcorerender\WindowsCompile\Build_CMake\LuxCore\src\luxcore\pyluxcore.vcxproj" (default target) (25) ->
       ile: cannot read at 0x82 [D:\CP\luxcorerender\WindowsCompile\Build_CMake\LuxCore\src\luxcore\pyluxcore.vcxproj]
Re: Building errors in Win10
Post by B.Y.O.B. » Sat Mar 02, 2019 5:28 pm
Do you have git LFS installed?
Fox
Post by Fox » Sat Mar 02, 2019 5:34 pm
No, i don't have. Can't i just use firefox to download files?
Post by B.Y.O.B. » Sat Mar 02, 2019 5:50 pm
No, unfortunately not, you need git with LFS extension.
It's mentioned in the readme: https://github.com/LuxCoreRender/Window ... README.txt
Fox
Post by Fox » Sat Mar 02, 2019 6:23 pm
I used now GitHub Desktop.
Got 8 warnings and 1 error.
The Error
       "D:\CP\luxcorerender\WindowsCompile\Build_CMake\LuxCore\src\pyluxcoretools\pyluxcoretools_copy_dir.vcxproj" (def
       ault target) (7) ->
       (CustomBuild target) ->
         C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\Common7\IDE\VC\VCTargets\Microsoft.CppCommon.ta
       rgets(209,5): error MSB6006: "cmd.exe" exited with code 1. [D:\CP\luxcorerender\WindowsCompile\Build_CMake\LuxCo
       re\src\pyluxcoretools\pyluxcoretools_copy_dir.vcxproj]
Fox
Post by Fox » Sat Mar 02, 2019 7:04 pm
yeey first build :D
Post by B.Y.O.B. » Sat Mar 02, 2019 7:34 pm
Congrats. What was the problem?
Fox
Post by Fox » Sat Mar 02, 2019 7:40 pm
:P
in command prompt
pip install pyinstaller
press enter
pip install PySide2
press enter
pip install numpy
press enter
acasta69
Post by acasta69 » Sun Mar 03, 2019 9:22 am
pip install PySide2
press enter
By the way, the command above will install the latest PySide2 version, and at the moment a bug prevents PyInstaller-packed executables using it to run properly.
If you plan to use the generated pyluxcoretool.exe, you need to install the previous PySide2 version with this command:
pip install pyside2==5.12.0 shiboken2==5.12.0
More info about this bug:
https://bugreports.qt.io/browse/PYSIDE-932
https://bugreports.qt.io/browse/PYSIDE-942
https://github.com/pyinstaller/pyinstaller/issues/4040
I have updated README.txt in WindowsCompile to warn about this.
Windows 10 64 bits, i7-4770 3.4 GHz, RAM 16 GB, GTX 970 4GB v382.05
Fox
Post by Fox » Sun Mar 03, 2019 11:26 am
Thank you acasta69 for the tip.
