clamping defautls
clamping defautls
Post by lacilaci » Thu Feb 14, 2019 3:22 pm
Since caching will help with gi and oidn can be turned on by default and also help with fireflies.
I'd suggest setting clamping to a default value of around 100 000. It doesn't take away much from sunlight and it effectively kills fireflies while some caustics are still possible.
The reason I'm suggesting using a default clamping is that in every other renderer this parameter works differently and new users could easily assume values from 5-25 (cycles, corona, vray etc) which are extreme. Also with those new luxcore features it is no longer needed to kill default strong sunlight as both caching and denoiser can easily work with that now.
