Page 2 of 3
Re: anisotropic metal UV problem
Posted: Sun Jan 27, 2019 7:24 pm
I think the U- and V-roughness in my example file were flipped.
I fixed that and I get a result very similar to your Cycles render now.
Does this work for you? File attached.
Posted: Sun Jan 27, 2019 7:55 pm
by JoeDDD
B.Y.O.B. wrote: ↑Sun Jan 27, 2019 7:24 pm
The reflection works fine now but it is still unusable due to artifacts. Mesh is subdivided 4 times and subdividing it 5th time would probably make my computer crash.
Here is my render:
Posted: Sun Jan 27, 2019 8:10 pm
Looks like your mesh has some problems, or maybe the UV map is not correct?
Can't you just append the disk from my example scene into your project and use it?
Posted: Sun Jan 27, 2019 8:28 pm
by JoeDDD
B.Y.O.B. wrote: ↑Sun Jan 27, 2019 8:10 pm
I fixed the knob mesh now and it works great. Thanks!
Posted: Sun Jan 27, 2019 8:55 pm
Nice.
Looks like an interesting scene by the way, will you show it once it's finished?
Posted: Sun Jan 27, 2019 9:15 pm
by JoeDDD
B.Y.O.B. wrote: ↑Sun Jan 27, 2019 8:55 pm
Nice.
Sure. It is an analog version of lux render (my first project with this render engine)
Posted: Thu Jan 31, 2019 8:38 am
by lighting_freak
I've tried to apply the given solution on a new mesh.
Working with the same material properties leads to a different render result.
Do you have any idea why?
Left disc is from aniso2.blend, right disc is mine:
This is the blend file.
BR
Posted: Thu Jan 31, 2019 10:12 am
You might have to mirror or rotate your UV mapping.
Posted: Thu Jan 31, 2019 11:15 am
by wasd
It's might be light falling at different angle.
Moved lamp a bit to the right:
With a sun lamp:
Posted: Fri Feb 01, 2019 4:50 pm
by JoeDDD
Nice.
This is how it looks right now with the real anisotropic shader.
