Adding Bump and Normal maps together
Post by Racleborg » Wed Jan 09, 2019 12:23 pm
Hi
What is the correct way to add a Bump and a Normal map together?
Is the method in the attached image correct?
Thank you
Re: Adding Bump and Normal maps together
Post by B.Y.O.B. » Wed Jan 09, 2019 12:49 pm
Yes. The actual math is more complicated, but LuxCore does that in the background for you (the add texture contains the necessary code and it is used if the output is a bump map).
Post by Racleborg » Wed Jan 09, 2019 12:50 pm
@B.Y.O.B
Many thanks
