It seems like render goes without modifier.
Geometry:
render with modifier:
render with applied:
Subdivision modifier
Re: Subdivision modifier
I can not reproduce the problem.
Do I have to do any extra steps?
When I open the file and press F12, I see this:
Hmm.. Maybe I din't update luxcore! upd: I have beta4 now, problem persist
upd: yep, if you open file and press f12, there will be object with applied modifier to render
You should choose layer[0], then render.
You have the render subdivisions set to 2, but viewport to 6.
Set render to the same as viewport.
Thank you very much!
for some reason I didn't expect subdivision on render be lesser than viewport no matter what the numbers are... that was not very smart of me
