Network Render time out
Posted: Sun Nov 25, 2018 12:50 pm
I'm continuing testing network rendering.
After running console and single node on a single machine this message appears in console:
At the same time this in node window:
From that point no step forward happens anymore.
BR
LuxCore 2.1beta2
NetBeaconReceiver thread started.
Discovered new node: 192.168.188.23:18018
Discovered new node: 192.168.188.25:18018
Creating single image render farm job: C:/Users/Martin/Desktop/Job/material_test__LuxCore/00001.bcf
New render farm job: C:/Users/Martin/Desktop/Job/material_test__LuxCore/00001.bcf
Job file md5: 5900a89effc82fa1661aeaba3e16e766
Job started: C:/Users/Martin/Desktop/Job/material_test__LuxCore/00001.bcf
Node thread started
Node thread started
Film merge thread started
Remote node has the same pyluxcore verison
Sending file: C:/Users/Martin/Desktop/Job/material_test__LuxCore/00001.bcf
Transfered 70.66 Mbytes in 00:00:00 (160.59 Mbytes/sec)
Sending seed: 2
Waiting for node rendering start
timed out
File "C:\Users\Martin\AppData\Local\Temp\_MEI69922\pyluxcoretools.zip\pyluxcoretools\renderfarm\renderfarmjobsingleimage.py", line 393, in NodeThread
nodeSocket.connect((self.renderFarmNode.address, self.renderFarmNode.port))
socket.timeout: timed out
Node thread done
LuxCore 2.1beta2
Waiting for configuration...
Started
NetBeaconSender thread started.
Waiting for a new connection
Received connection from: ('192.168.188.25', 49923)
Remote pyluxcore version: 2.1beta2
Local pyluxcore version: 2.1beta2
Receiving RenderConfig serialized file: renderfarmnode-e285a2ce-8c6d-48c5-ac31-9b0fb12e3924.bcf
Receiving file: renderfarmnode-e285a2ce-8c6d-48c5-ac31-9b0fb12e3924.bcf
Receiving RenderConfig serialized MD5: 5900a89effc82fa1661aeaba3e16e766
Received seed: 2
Reading RenderConfig serialized file: renderfarmnode-e285a2ce-8c6d-48c5-ac31-9b0fb12e3924.bcf
[SDL][101.728] Loading serialized mesh: Mesh-Mesh_Glass_Outer_236511528000
[SDL][101.728] Loading serialized mesh: Mesh-Mesh_Glass_Trans_236513016000
[SDL][101.791] Loading serialized mesh: Mesh-Mesh_Glass_Inner_236510040000
[SDL][101.994] Loading serialized mesh: Mesh-Mesh_Screw_236533848000
[SDL][101.994] Loading serialized mesh: Mesh-Mesh_Tube__top_298642776000
[SDL][102.009] Loading serialized mesh: Mesh-Curve_Post__1_236530872000
[SDL][102.009] Loading serialized mesh: Mesh-Curve_Post__2_236532360000
[SDL][102.009] Loading serialized mesh: Mesh-Curve_Support__1_236535336000
[SDL][102.009] Loading serialized mesh: Mesh-Curve_Support__2_298639800000
[SDL][102.009] Loading serialized mesh: Mesh-Mesh_Filament_236508552000
[SDL][102.009] Loading serialized mesh: Mesh-Mesh_Top__tube_298641288000
[SDL][102.009] Loading serialized mesh: Mesh-Mesh_Outer__tube_236523432000
[SDL][102.009] Loading serialized mesh: Mesh-Curve_Wire__1_298644264000
[SDL][102.009] Loading serialized mesh: Mesh-Mesh_Inner__tube_236520456000
[SDL][102.009] Loading serialized mesh: Mesh-Curve_Wire__2_298645752000
[SDL][102.009] Loading serialized mesh: Mesh-Mesh_Glue_236514504000
[SDL][102.009] Loading serialized mesh: Mesh-Mesh_Isolator_236521944000
[SDL][102.009] Loading serialized mesh: Mesh-Mesh_Bottom__Contact_236578536000
[SDL][102.009] Loading serialized mesh: Mesh-Mesh_Cylinder_236507064000
[SDL][102.009] Loading serialized mesh: Mesh-Mesh_Cube__001_236505576000
[SDL][102.009] Loading serialized mesh: Mesh-Mesh_Cube_236584488000
[SDL][102.025] Loading serialized mesh: Mesh-Mesh_Icosphere__002_236518968000
[SDL][102.025] Loading serialized mesh: Mesh-Mesh_Icosphere__001_236517480000
[SDL][102.040] Loading serialized mesh: Mesh-Mesh_Icosphere_236515992000
[SDL][102.040] Loading serialized mesh: Mesh-Mesh_Plane__003_236529384000
[SDL][102.040] Loading serialized mesh: Mesh-Mesh_Plane__002_236527896000
[SDL][102.040] Loading serialized mesh: Mesh-Mesh_Plane__001_236526408000
[SDL][102.040] Loading serialized mesh: Mesh-Mesh_Plane_236524920000
BR
