Network Render time out
lighting_freak
Post by lighting_freak » Sun Nov 25, 2018 12:50 pm
I'm continuing testing network rendering.
After running console and single node on a single machine this message appears in console:
LuxCore 2.1beta2
NetBeaconReceiver thread started.
Discovered new node: 192.168.188.23:18018
Discovered new node: 192.168.188.25:18018
Creating single image render farm job: C:/Users/Martin/Desktop/Job/material_test__LuxCore/00001.bcf
New render farm job: C:/Users/Martin/Desktop/Job/material_test__LuxCore/00001.bcf
Job file md5: 5900a89effc82fa1661aeaba3e16e766
Job started: C:/Users/Martin/Desktop/Job/material_test__LuxCore/00001.bcf
Node thread started
Node thread started
Film merge thread started
Remote node has the same pyluxcore verison
Sending file: C:/Users/Martin/Desktop/Job/material_test__LuxCore/00001.bcf
Transfered 70.66 Mbytes in 00:00:00 (160.59 Mbytes/sec)
Sending seed: 2
Waiting for node rendering start
timed out
  File "C:\Users\Martin\AppData\Local\Temp\_MEI69922\pyluxcoretools.zip\pyluxcoretools\renderfarm\renderfarmjobsingleimage.py", line 393, in NodeThread
    nodeSocket.connect((self.renderFarmNode.address, self.renderFarmNode.port))
socket.timeout: timed out
Node thread done
At the same time this in node window:
LuxCore 2.1beta2
Waiting for configuration...
Started
NetBeaconSender thread started.
Waiting for a new connection
Received connection from: ('192.168.188.25', 49923)
Remote pyluxcore version: 2.1beta2
Local pyluxcore version: 2.1beta2
Receiving RenderConfig serialized file: renderfarmnode-e285a2ce-8c6d-48c5-ac31-9b0fb12e3924.bcf
Receiving file: renderfarmnode-e285a2ce-8c6d-48c5-ac31-9b0fb12e3924.bcf
Receiving RenderConfig serialized MD5: 5900a89effc82fa1661aeaba3e16e766
Received seed: 2
Reading RenderConfig serialized file: renderfarmnode-e285a2ce-8c6d-48c5-ac31-9b0fb12e3924.bcf
[SDL][101.728] Loading serialized mesh: Mesh-Mesh_Glass_Outer_236511528000
[SDL][101.728] Loading serialized mesh: Mesh-Mesh_Glass_Trans_236513016000
[SDL][101.791] Loading serialized mesh: Mesh-Mesh_Glass_Inner_236510040000
[SDL][101.994] Loading serialized mesh: Mesh-Mesh_Screw_236533848000
[SDL][101.994] Loading serialized mesh: Mesh-Mesh_Tube__top_298642776000
[SDL][102.009] Loading serialized mesh: Mesh-Curve_Post__1_236530872000
[SDL][102.009] Loading serialized mesh: Mesh-Curve_Post__2_236532360000
[SDL][102.009] Loading serialized mesh: Mesh-Curve_Support__1_236535336000
[SDL][102.009] Loading serialized mesh: Mesh-Curve_Support__2_298639800000
[SDL][102.009] Loading serialized mesh: Mesh-Mesh_Filament_236508552000
[SDL][102.009] Loading serialized mesh: Mesh-Mesh_Top__tube_298641288000
[SDL][102.009] Loading serialized mesh: Mesh-Mesh_Outer__tube_236523432000
[SDL][102.009] Loading serialized mesh: Mesh-Curve_Wire__1_298644264000
[SDL][102.009] Loading serialized mesh: Mesh-Mesh_Inner__tube_236520456000
[SDL][102.009] Loading serialized mesh: Mesh-Curve_Wire__2_298645752000
[SDL][102.009] Loading serialized mesh: Mesh-Mesh_Glue_236514504000
[SDL][102.009] Loading serialized mesh: Mesh-Mesh_Isolator_236521944000
[SDL][102.009] Loading serialized mesh: Mesh-Mesh_Bottom__Contact_236578536000
[SDL][102.009] Loading serialized mesh: Mesh-Mesh_Cylinder_236507064000
[SDL][102.009] Loading serialized mesh: Mesh-Mesh_Cube__001_236505576000
[SDL][102.009] Loading serialized mesh: Mesh-Mesh_Cube_236584488000
[SDL][102.025] Loading serialized mesh: Mesh-Mesh_Icosphere__002_236518968000
[SDL][102.025] Loading serialized mesh: Mesh-Mesh_Icosphere__001_236517480000
[SDL][102.040] Loading serialized mesh: Mesh-Mesh_Icosphere_236515992000
[SDL][102.040] Loading serialized mesh: Mesh-Mesh_Plane__003_236529384000
[SDL][102.040] Loading serialized mesh: Mesh-Mesh_Plane__002_236527896000
[SDL][102.040] Loading serialized mesh: Mesh-Mesh_Plane__001_236526408000
[SDL][102.040] Loading serialized mesh: Mesh-Mesh_Plane_236524920000
From that point no step forward happens anymore.
BR
OS - Windows 7 X64
CPU - Intel CORE i7
BiOzZ
Re: Network Render Exporterror
Post by BiOzZ » Sun Nov 25, 2018 6:48 pm
I too have a similar problem, i'm using an offsite render box, ports are forwarded, and console is running on the external machine
on the console on windows i get (i redacted the IP, its the hosts public IP)
LuxCore 2.0
Discovered new node: [Host Public IP]:18018
Creating single image render farm job: C:/Users/Alyx/Desktop/LuxBench/1_LuxCore/00056.bcf
New render farm job: C:/Users/Alyx/Desktop/LuxBench/1_LuxCore/00056.bcf
Job file md5: f3e256ca026a9bde54b399a5bb331192
Job started: C:/Users/Alyx/Desktop/LuxBench/1_LuxCore/00056.bcf
Node thread started
timed out
  File "C:\Users\ALYX\AppData\Local\Temp\_MEI82922\pyluxcoretools.zip\pyluxcoretools\renderfarm\renderfarmjobsingleimage.py", line 393, in NodeThread
Node thread done
The node output on the server running on linux
LuxCore 2.0
Started
That output is more or less mirrored in the console
the netnode tool is also asking me to input an IP address, putting my (client) IP address does nothing to solve it, putting loopback ip does nothing, putting its own public ip does nothing, putting it or my local IPs do nothing.
Re: Network Render time out
Post by Dade » Mon Nov 26, 2018 8:31 am
This is a problem I was told it was gone some time ago. It happens only when Windows is involved. As far as I know, it works fine with Linux. I guess I will have gain to look into it.
Post by Dade » Mon Nov 26, 2018 9:07 am
On a second thought, the error is a time out and it is thrown when try to establish the connection (i.e. the original problem was a dead-lock). 99% of times, this is the result of some firewall/anti-virus related problem. For instance, on my Linux box I have to disable the FW even when running both the console and the node on the local machine because FW rules are applied to localhost interface too.
BiOzZ
Post by BiOzZ » Mon Nov 26, 2018 4:30 pm
Disabling software firewall on windows (antivirus and defender) along with the hardware firewall (both of these i manually implemented exceptions for this previously) did not solve the problem.
the linux server has no third party firewall in software and no hardware firewall so i have my doubts its rejecting this traffic based on any odd linux default rules.
