I have an issue with smooth shading.
First I noticed it only with bump map, but then I created the attached sample scene, which shows the error even without bump.
I use v2.1 beta2.
Shading issue
Shading issue
- Attachments
- shading_issue.blend
- (534.09 KiB) Downloaded 128 times
Re: Shading issue
That's the terminator problem.
See the FAQ (on the bottom):
https://wiki.luxcorerender.org/BlendLux ... _penumbras
Re: Shading issue
Well, thanks. I see it isn't a LuxCore specific problem.B.Y.O.B. wrote: ↑Sat Nov 17, 2018 11:01 am That's the terminator problem.
In my original scene it was caused by a hdri, therefore I couldn't increase the size of the light, so I used heavy subsurf, and it solved the issue.
