Lux Render sample not rendering correctly
checoimg
Post by checoimg »
Hi everyone, I'm a noob checking out this renderer. I'm trying to render the samples but one crashes blender and the other doesn't render correctly.
https://pasteboard.co/HNuIl3X.png
Re: Lux Render sample not rendering correctly
Are you using v2.0 to load these?
The example scenes were made with the v2.1 dev versions, so you will need the latest v2.1beta2 to render them correctly.
I have added a note to the download page.
checoimg
Post by checoimg »
the upgrade is not working, the last image shows a warning sign for the update. Don't know what that means
https://pasteboard.co/HNznB5b.png
https://pasteboard.co/HNzoive.png
https://pasteboard.co/HNzvYXS.png
https://pasteboard.co/HNzwzFi.png
The warning icon just says that this is an experimental version (alpha/beta).
Does rendering work after you restart Blender?
checoimg
Post by checoimg »
the problem seems to be the "embree.dll" is not named correctly to "embree3.dll"
https://pasteboard.co/HNzLUCS.png
reference post viewtopic.php?t=403
Ah yes this is a known (and unsolvable) problem.
You can't use the updater in v2.0 to update to v2.1.
You will have to remove the old addon first, then install the new one from the zip.
This is also mentioned in the "How to update" section of the installation instructions: https://wiki.luxcorerender.org/BlendLux ... stallation
checoimg
Post by checoimg »
Where do I get 2.1?
checoimg
Post by checoimg »
Thanks so much! I'm leaving the installation wiki here https://wiki.luxcorerender.org/BlendLux ... rs_of_v2.0
Here's my render https://pasteboard.co/HNAiVeV.png 1500 samples, 53:29
