Max Brightness Value
Re: Max Brightness Value
Post by Racleborg » Fri Nov 16, 2018 9:00 am
Hi
I've sorted myself out with Dropbox, and here is a link to the file: https://1drv.ms/u/s!AhdwgLaw01tLjw9eOm3tpXFb4UZS
Everything has been taken out except the Mesh-Lights, Sun and camera.
If you need some meshes putting back; I can do that but it can gets quite large to upload.
Cheers
Post by B.Y.O.B. » Fri Nov 16, 2018 9:08 am
I can't reproduce the issue.
Post by Dade » Fri Nov 16, 2018 9:24 am
Here too :?: Do you always get the NaN ? By just opening the scene and starting the rendering ?
Post by Racleborg » Fri Nov 16, 2018 9:35 am
I've only had the NAN once.
The scene I am working on is still very WIP and I'm adding more and more stuff to it, so there is a chance it will re-occur and as soon as it does I'll save a copy of it at that point for you. Unless of course there is anything else you would like me to do in the meantime?
Post by Dade » Fri Nov 16, 2018 11:26 am
Just let see if it happen again or not.
Post by Racleborg » Fri Nov 16, 2018 2:36 pm
It's just done it again. (Snip image attached).
If you could just bear with me whilst I upload the whole project as our broadband connection is rubbish!
Post by Racleborg » Fri Nov 16, 2018 4:06 pm
Post by Dade » Fri Nov 16, 2018 4:09 pm
The scene is not going to be very useful anyway if it is not something I can reproduce in a reasonable number of tries. When do you get the NaN value ? Soon after starting the rendering ? At some point during the rendering ?
@B.Y.O.B.: at what point do you call the get film luminance method in BlendLuxCore ?
Post by Racleborg » Fri Nov 16, 2018 4:20 pm
Sorry, I don't understand the question.
Post by Dade » Fri Nov 16, 2018 4:21 pm
Ok, I see, just opening the scene, shows a NaN value. @B.Y.O.B. is it an uninitialized variable ? Where does it come from as soon after having just opened the file ?
