Page 2 of 4
Re: Different exposure when rendering different parts of the image
Posted: Wed Nov 14, 2018 3:32 pm
by alpistinho
FXtend wrote: ↑Wed Nov 14, 2018 3:25 pm
How would it help to adjust both rather than just one?
I believe that after reversing the gamma for both sides they will be a multiplication away from each other.
So you would need to reverse the gamma for both sides, multiply one of them to make them equal and then apply the gamma correction again.
Posted: Sat Nov 17, 2018 4:13 pm
by FXtend
Thanks for all the feedback
I think I've found a solution. There's a little bit of overlap between the halves so I'm thinking that if I render a few pixels within that overlap without gamma correction I should be able to set up a system of equations. I tried without this extra render but then I got eight equations and eight unknown variables whereas this method should give me only four and, well, I'm lazy
All I need to do is make sure that Auto Brightness is disabled, right?
Posted: Sat Nov 17, 2018 4:30 pm
FXtend wrote: ↑Sat Nov 17, 2018 4:13 pm
Yup.
Posted: Sat Nov 17, 2018 4:35 pm
This is right. I would render a preview, adjusting brightness manually in linear tonemapper during rendering and then stop and restart wirh final resolution.
I am very curious how your rerender will top your already fantastic work.
Posted: Sun Nov 18, 2018 3:21 pm
by FXtend
FarbigeWelt wrote: ↑Sat Nov 17, 2018 4:35 pm
Okay, I think you've sort of misunderstood my strategy. I don't want to rerender the full scene since I don't feel like waiting another month for my scene be finished. My idea is to figure out the gamma and gain by sampling both halves and a tiny render without gamma correction in order to set up a system of four equations that should give me the factor (gain?) and gamma value.
Thanks
I think I'll top it by having the same gamma on both halves and applying some lens flares and color correction and stuff
Posted: Sun Nov 18, 2018 3:23 pm
Have you tried what alpistinho suggested?
Reverse gamma correction is just gamma correcting with gamma = 1/2.2.
alpistinho wrote: ↑Wed Nov 14, 2018 3:32 pm
Posted: Sun Nov 18, 2018 3:53 pm
by Racleborg
A month!? That's a very long time. Is this usual for some scene types?
Posted: Sun Nov 18, 2018 5:45 pm
by FXtend
B.Y.O.B. wrote: ↑Sun Nov 18, 2018 3:23 pm
That's what I'm trying to do but I need the gamma values and factors. That's what the equations are for.
I'm assuming Luxcore does gamma correction according to
Maybe that's where I'm wrong because it still doesn't look good after solving the equations
Posted: Sun Nov 18, 2018 5:53 pm
by FXtend
Racleborg wrote: ↑Sun Nov 18, 2018 3:53 pm
That is very long indeed. Keep in mind that most of the sunlight has to go through both the fog and the water where it's refracted and dispersed and bounce around inside the pipe. I mean, interiors can be heavy but I think I've created something extreme
I don't know if this sort of render time should be considered acceptable still but that's all I know. Oh, and it's 4K.
Maybe I could have done with a little fewer samples...
Posted: Sun Nov 18, 2018 6:43 pm
by Racleborg
Well, it looks great! So if it takes a month, then it takes a month
