Page 1 of 4
Different exposure when rendering different parts of the image
Posted: Tue Nov 13, 2018 3:29 pm
by FXtend
My render seems to always crash after about a week of rendering so I decided to split it in two parts. This obviosly solved the problem since I've been able to let it run for more than two weeks without any trouble. However, when I brought the two parts into After Effects for compositing, I realized that there's a huge brightness and color difference between the two parts. I assume that this is caused by some sort of auto exposure in Lux.
So, my question is this: is it possible to find out the exact exposure difference between the parts and what's the best (preferably mathematically correct) way to fix it in post? I've played around with exposure, brightness/contrast, curves, tint and hue/saturation in AE but it always seems too dark in some places or too bright in others
Both parts were saved as exr.
Re: Different exposure when rendering different parts of the image
Posted: Tue Nov 13, 2018 3:54 pm
Which tonemapper did you use?
If you don't know, you can upload the .cfg or .blend file.
Also, which version of Lux? Did you use the Blender addon, or some different solution?
Posted: Tue Nov 13, 2018 3:56 pm
FXtend wrote: ↑Tue Nov 13, 2018 3:29 pm
Are you using Auto-Linear tone mapping ? In this case, it auto scales the image luminance and it explains your result. You should have used Linear tone mapping with the same user defined scale for both renderings.
To merge your already rendered images, it should be possible to scale up/down on of the half images to match the other half. Auto-Linear tone mapping just multiply the RGB values for a constant. It should be possible to multiply again one of the half-images for another constant to match the value used in other half.
Posted: Tue Nov 13, 2018 6:07 pm
by FXtend
Dade wrote: ↑Tue Nov 13, 2018 3:56 pm
Yep, linear with auto brightness
Thanks for the maths
I tried multiplying the brighter half with different shades of grey but I still have the same issue; some parts are too bright while others are too dark and the seam is clearly visible
Posted: Tue Nov 13, 2018 8:42 pm
FXtend wrote: ↑Tue Nov 13, 2018 6:07 pm
Efff, unfortunately, my original post wasn't accounting for gamma correction: it makes the process not linear. So you would have to reverse gamma correct the half image and, only after that step, you can scale the image and than gamma correct again. Sadly, this is a very complicate process because, like said, it is not linear and it is very hard to adjust accounting the gamma correction step.
Posted: Tue Nov 13, 2018 9:14 pm
by Racleborg
The scene looks incredible! The bee, the flower, the lighting - wow!
I'd really like to see it when it's finished.
Posted: Tue Nov 13, 2018 10:05 pm
Dade wrote: ↑Tue Nov 13, 2018 8:42 pm
Well, you can reverse gamma correct both half so you can match one luminance scale with the other.
Posted: Tue Nov 13, 2018 10:25 pm
Anyway your image look already unbelievable can't wait the end
Posted: Wed Nov 14, 2018 3:25 pm
by FXtend
Dade wrote: ↑Tue Nov 13, 2018 10:05 pm
How would it help to adjust both rather than just one?
Posted: Wed Nov 14, 2018 3:31 pm
by FXtend
Racleborg wrote: ↑Tue Nov 13, 2018 9:14 pm
Sharlybg wrote: ↑Tue Nov 13, 2018 10:25 pm
Thanks guys
Really appreciate that after all the trouble I've had with this scene.
