Rendered viewport on hold
stefdln
Post by stefdln » Tue Nov 06, 2018 12:41 pm
Hello everyone
Found a bug in Luxcore so I thought I would let you know so you guys can fix it
Basically what I did was I had this rendered viewport, hit F12 to open a render view in the same panel, then in this same panel opened a rendered viewport again and bam, that's what happened.
Viewport halt time set to 20 s
I've been facing this problem every now and then lately.
It's no big deal since I think refreshing some settings might make this problem disappear but it might be annoying in some cases I guess.
Check the attached vid for further details
Cheers
https://youtu.be/cM3GdBjtnIU
