DLCS and Round objects
Re: DLCS and Round objects
Post by kintuX » Fri Nov 02, 2018 11:58 pm
lacilaci wrote:
Fri Nov 02, 2018 4:59 am
Do you understand that this is a simplified scene to show an issue I'm having with dlcs?
Or do you plan to tell me on every issue I find that I should either fix it my self or learn to work around the issue, or simply stop using luxcore?
Did a couple of similar tests which all gave bad and even worse results, so i assumed issue comes from improper use.
Thanks to you, issue is now fixed and I offer an apology for my bad assumption and disregarding your efforts to make this engine better.
Be well and keep up the spirit! :)
Post by lacilaci » Sat Nov 03, 2018 6:15 am
It's all good.
