Camera exterior volume
Post by B.Y.O.B. » Mon Jan 22, 2018 10:17 pm
it seems like the camera has no exterior volume property in LuxCore.
This leads to wrong renders if the camera is e.g. inside of a cube with a volume.
Can this feature be added?
00005.zip
(20.9 KiB) Downloaded 84 times
Re: Camera exterior volume
Post by Dade » Mon Jan 22, 2018 10:33 pm
Are you looking for world volume (scene.world.volume.default):
scene.volumes.vol_air.type = homogeneous
scene.volumes.vol_air.absorption = 0.0 0.0 0.0
scene.volumes.vol_air.scattering = 0.04 0.04 0.04
scene.volumes.vol_air.asymmetry = 0.0 0.0 0.0
scene.volumes.vol_air.multiscattering = 0
scene.world.volume.default = vol_air
https://github.com/LuxCoreRender/LuxCor ... ic.scn#L13
Post by B.Y.O.B. » Mon Jan 22, 2018 10:54 pm
I guess I am looking for that :)
Thanks.
edit: However, that would set this volume as default for all materials and lights, right?
What if I only want the camera to be in a volume, but not e.g. the sun?
I would have expected a "scene.camera.volume" setting.
Post by Dade » Mon Jan 22, 2018 11:41 pm
Thanks.
The default volume is used when the object lack of volume definitions. Just use an object with null material and an interior volume and place the camera inside the object.
Post by Dade » Mon Jan 22, 2018 11:43 pm
I am on a tablet at the moment, looking at your scene, have you assigned the monkey outside volume ?
Post by B.Y.O.B. » Tue Jan 23, 2018 12:06 am
This was the problem, thanks, it works like expected now.
