I have been having a problem while trying to add a carpet to a scene where, when I select "UV Texture Map" for the hair color export mode, the hair does not show in the viewport or final render.
I remember having this issue in classic luxrender, however the old forums that are linked from Google search results are no longer accessible.
What am I doing wrong? Do I need to recompile from newer sources? Thanks in advance.
Hair Dissapears with UV Texture Map Color Export
Calling all Linux users: check out the new LuxRender 1.7 Flatpak! https://github.com/rrubberr/Flatpak-LuxRender
Light transport enthusiast - www.rrubberr.com
Re: Hair Dissapears with UV Texture Map Color Export
Can you upload the scene?
The scene is over 300 mb; I'll try recreating the carpet and see if that fixes it.
You can also append the carpet into a new file.
