v2.1alpha2 crash
Re: v2.1alpha2 crash
Post by Dade » Wed Aug 08, 2018 9:57 am
Dade wrote:
Sat Aug 04, 2018 8:46 pm
Fox wrote:
Fri Aug 03, 2018 2:43 pm
I did 800 x 1200 pix and still crashes with 10-11GB of memory use.
No crash in alpha1, the memory use goes there to 14GB that leaves 90% free memory.
I start to have the feeling is a regression I have already fixed so I can not reproduce the problem with the latest sources. I will try if it happens with alpha2 sources.
Alpha2 doesn't crash for me on Linux but produces some wrong rendering so I assume it is the same problem causing the crash for you. Binaries compiled from latest sources work fine (like alpha1). Alpha3 should be released today and it should fix the problem for you.
Fox
Post by Fox » Wed Aug 08, 2018 4:30 pm
Thank you. alpha3 works, both the luxcoreui and blendluxcore.
