DLSC test
DLSC test
Post by Sharlybg » Wed Jul 04, 2018 3:59 pm
Hi ! just open this thread for testing and learning purposes about DLCS as said in the title. I wish to test here many diferent test scene where DLCS shine.
this is my first scene. it is yet unfinished but want to understand more before i add more stuff.
.Why DLCS lighting is so diferent from log power/power strategy ? it deliver so much light
. I also have some strange black artifact
EDIT
Scene file here :
https://drive.google.com/open?id=1237dq ... EQh9Sg5adH
Re: DLCS test
Post by Sharlybg » Wed Jul 04, 2018 10:42 pm
Dade wrote:
Wed Jul 04, 2018 9:19 pm
B.Y.O.B. wrote:
Wed Jul 04, 2018 5:56 pm
As far as I understand it, the light cache only adjusts the probabilities of a light being sampled and is still unbiased.
Correct.
The phenomenon in the linked image might be startup bias or something else caused by not enough samples (but it is a bit hard to tell without a ground truth image).
It is noise, a (huge) different level of noise. DLSC fallback to standard log power light strategy when a valid cache entry is not avilable for the point I'm rendering. It is very noticeable. Look, this is a scene with a well populated cache (1 sample per pixel):
and this is the same scene with not enough cache entries:
The surfaces without a valid cache entry are very easy to spot due the HUGE difference in noise. It is still unbiased so it will converge to the same result but in practice they look as artifacts.
Re: DLCS test
Post by B.Y.O.B. » Thu Jul 05, 2018 7:52 am
Have you tried a smaller entry radius?
(nice scene btw.)
Re: DLCS test
Post by Dade » Thu Jul 05, 2018 8:38 am
I'm looking into the scene but before to start I'm checking a strange problem I have when exporting the scene in text format.
Re: DLCS test
Post by Sharlybg » Thu Jul 05, 2018 10:25 am
(nice scene btw.)
thanks you glad you like it !
here is a render with entry 10cm and max passes to 10000 : As can see there is black artifacts on the ladder. It also lead to longer precomputation time. And falling to very low entry like 2cm take forever to compute and freeze blender.
Re: DLCS test
Post by kintuX » Thu Jul 05, 2018 11:54 am
I think,
- the smaller the radius, the more samples there are & the more computation is needed
- dark artifacts, from my observations happen only on shadow's edges under some special (?) conditions (most distinctive with shadow catcher used).
Re: DLCS test
Post by Sharlybg » Sat Jul 07, 2018 11:51 pm
Another test both rendered in 2hrs and again light cache take a very very long time to compute when it's under around 10cm :
.DLCS :
.UNIFORM :
Re: DLCS test
Post by Dade » Sun Jul 08, 2018 9:02 am
There was a bug in area light source power computation (when the using power/efficiency parameters) causing power light strategies to erroneously sample only the soft area light outside the windows.
Re: DLCS test
Post by Sharlybg » Thu Jul 26, 2018 9:34 pm
Thanks for solving this. Also do you think the longer precomputation time is a normal behaviour ? And can we do valid test DLCS with the current development stage ?
Re: DLCS test
Post by lacilaci » Mon Sep 03, 2018 6:55 am
I wonder too how complete/incomplete this feature is. In some cases even small entry radius gives me visible sample areas (2.1alpha3) where the edge of the shadow is just "blotchy" it doesn't matter if I use sun, sky, hdri or area lights.
