Graphics Card Not Showing Up
Rqindash
Post by Rqindash »
My problem is that in BlendLuxCore LuxCore Config clicking the OpenCL option it doesn't show my GPU as an available device. I have tried dozens of different ways to make my £100 graphics card work :<
I am using Blender 2.79b and BlendLuxCore 2.0 and my PC Specs are as follows:
CPU:Intel Pentuim G4560
GPU:AMD Radeon R9 270X
RAM:4GB DDR4
Motherboard:B250M Mortar
Any help will be appreicated.
Re: Graphics Card Not Showing Up
Rqindash wrote: Fri Jun 01, 2018 9:23 am My problem is that in BlendLuxCore LuxCore Config clicking the OpenCL option it doesn't show my GPU as an available device. I have tried dozens of different ways to make my £100 graphics card work :<
Start to check if your OpenCL support is working fine by trying to run LuxMark ? Does it work ?
Check also if you have downloaded and installed the BlendLuxCore version with OpenCL support (and not the one without) from the Download page.
Rqindash
Post by Rqindash »
LuxMark does not work with my GPU installed however it does with my Intergrated Graphics
I am also using the OpenCL version
I think it is something to do with my card. I will try to fix.
Rqindash
Post by Rqindash »
Don't worry, I just needed to reinstall Windows as I installed my GPU prior to Windows installation.
