console denoise save file
zukazuka
Post by zukazuka »
When rendering from console ("batch render script") I select denoise on:
bpy.context.scene.luxcore.denoiser.enabled=True
The render is denoised but the result is saved as a separate pass "DENOISED" pass - it seems when I save image via:
bpy.data.images['Render Result'].save_render("out.png")
It only saves the "Combined" pass but not the Denoised image.
I haven't tried to figure out how to combine the passes via python - I thought I would ask first to see what your suggestion is to save the "DENOISED" pass when rendering from a command line batch render script?
Re: console denoise save file
You can save as multilayer EXR, this contains all the passes.
However it can only be opened by very few programs (one of them Blender).
Another option is to create a small compositing node setup where you pipe the outputs that should be saved into a file output node:
https://docs.blender.org/manual/en/dev/ ... /file.html
zukazuka
Post by zukazuka »
Here's what I wrote so far (seems to be working).
This script will save the denoised result automatically so if you are rendering on a server or batch processing - you can save the denoised version automatically:
import bpy
scene = bpy.context.scene
# make sure we have node tree
if scene.node_tree==None:
    scene.use_nodes=True
#if denoiser not enabled = no denoiser node output, so make sure it's enabled
if scene.node_tree:
    nodes = scene.node_tree.nodes
    auto_denoise_output_label="auto_denoise_save"
    # remove previously auto created denoise nodes to prevent duplicates
    for node in nodes:
        if node.label==auto_denoise_output_label:
            nodes.remove(node)
    render_layers = nodes.new("CompositorNodeRLayers")
    render_layers.location=(0,0)
    render_layers.label=auto_denoise_output_label
    output_file = nodes.new("CompositorNodeOutputFile")
    output_file.location=(200,0)
    output_file.inputs[0].name="filename"
    output_file.base_path = "/home/me/blender_output_path/"
    output_file.file_slots[0].path="filename"
    output_file.label=auto_denoise_output_label
    scene.node_tree.links.new(render_layers.outputs['DENOISED'],output_file.inputs[0])
