Object texture from an image
igall2
Post by igall2 »
I'm trying to create an object texture from an image.
For LuxRender, I found the following instructions to do so:
B.Y.O.B. wrote:Follow these steps:
  • Create a new material for your object
  • Go to textures tab and create a new texture
  • choose "image texture" in the "Luxrender texture type" section
  • add in the path to your texture
  • go back to the materials settings
  • press the "T" right of "diffuse color"
  • choose your texture from the dropdown menu there
Are those instructions still valid?
I had a problem to follow the last two steps - didn't find those controls in Blender LuxCore.
Thanks in advance,
Igal
Re: Object texture from an image
No, this was for the old addon.
In the new addon, you open the node editor, switch to material nodes, press Shift+A -> Texture -> Imagemap, choose the image (either from the already loaded images or open a new one from disk), and connect the imagemap node's output with the color input of your material.
erfizt
Post by erfizt »
Thank you very much for this great add on
