Dear reader,
I installed luxcore renderer for blender just today, but i cant seem to figure out where the output of the rendered image is. I hope somone can help.
Regards, zeil
Render output
Re: Render output
i assume you mean blenderLuxCore if it is the case you will find it in render settings.
Re: Render output
Or you go through the Compositor and write the file (and other optional passes) out via the File Output node. This is how it's usually done. You should find plenty of tutorials about that online.
Re: Render output
Aaah, it is super easy, tnx. I had another question. How do i stop the render?
Re: Render output
Regularly - by setting a Halt Condition. Irregularly - by hitting ESCAPE (in this case the file output via the Compositor will be skipped).
