I noticed that using displacement and vertex color together results in crashing Blender. I'm using Blender 2.91.2 and LuxCore 2.5beta1 on Windows 10.
Attached is a small example scene. If you delete the vertex color, everything is fine. Add it and Blender crashes.
Since Harlequin Shape uses vertex colors too, it also causes a crash.
Does anyone else notice this behavoir?
Displacement + Vertexcolor crashes Blender
- DisplacementTest.blend
- (805.38 KiB) Downloaded 112 times
Re: Displacement + Vertexcolor crashes Blender
I can't reproduce this on Win 10 with the latest build. Maybe it was fixed since v2.5beta1?
You could try the latest build: https://github.com/LuxCoreRender/BlendL ... tag/latest
Problem solved. I tried with the latest build and it works fine.
Thank you for the fast response B.Y.O.B.
