Setting Image for Spot Projector
igall2
Post by igall2 » Mon May 07, 2018 3:11 pm
I'm trying to set the Image of Spot Projector from the Python Console of Blender, with the following line of code:
bpy.data.lamps['Spot'].luxcore.image = bpy.data.images['AAA.png']
As a result, I get an error:
File "C:\Users\igall\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore\properties\light.py", line 60, in update_image
if context.lamp:
AttributeError: 'Context' object has no attribute 'lamp'
Despite the error, the field is being updated:
But the render results are unstable: sometimes the rendered image comes out with the pattern, and sometimes without.
What could be the reason for the problem?
Is there a better way to set the Image of Spot Projector from the Python Console of Blender?
Many thanks!
Igal
Re: Setting Image for Spot Projector
Post by B.Y.O.B. » Mon May 07, 2018 4:14 pm
I fixed the exception being thrown and another issue.
However as you noted, it was only a "cosmetic" problem, since the image is still updated.
Sounds strange and I doubt it has anything to do with the rest (doesn't matter if the image was changed from UI or from Python).
Maybe it is related to this issue: https://github.com/LuxCoreRender/BlendL ... issues/152
Is your image a generated image? If yes, try to save it to disk.
By the way, you can find all properties here: https://github.com/LuxCoreRender/BlendL ... properties
Here is the faulty "update_image()" method: https://github.com/LuxCoreRender/BlendL ... ght.py#L72
And this is the fix: https://github.com/LuxCoreRender/BlendL ... 313625f46e
igall2
Post by igall2 » Tue May 08, 2018 7:52 am
Thanks B.Y.O.B!
I took your fix and updated to the latest version.
I'm loading my image from the disk with the following lines of code:
image_name = os.path.basename(pattern_path)
bpy.ops.image.open(filepath=image_name, directory=os.path.dirname(pattern_path),
files=[{"name": image_name}], relative_path=False, show_multiview=True)
Still, the pattern existence in the render results is unstable.
That's how my results look like. It is a scene with two cameras. Each camera yields randomly a result with or without the pattern.
What else could be possible to solve this please? :roll:
Post by B.Y.O.B. » Tue May 08, 2018 8:06 am
Can you upload an example scene showing the problem?
igall2
Post by igall2 » Tue May 08, 2018 2:23 pm
Done.
Here is the link:
https://drive.google.com/file/d/1COTFuz ... sp=sharing
Important note:
The problem appeared on a Win10 x64 PC with GTX 1070 GPU and i7-8700K CPU
The problem didn't appear on a Win7 x64 PC with AMD Radeon R7 M360 GPU and i7-6600U CPU
To replicate the problem:
  • Download and unzip
  • In command line, go to the unzipped folder
  • Run the following command:
    blender.exe --background "LuxRenderTest.blend" --python "render_scene.py"
The multilayer EXR results of the rendering will appear in the same folder, in subdirectories "Left" and "Right".
I also placed in the folder a Jupyter notebook script that opens and shows the multilayer EXRs, open_multilayer_exrs.ipynb
Igal
Post by B.Y.O.B. » Tue May 08, 2018 4:37 pm
I'm not sure if this is a problem in BlendLuxCore or in your script.
I would recommend to change your set_module_coord_frames() function in the following way:
replace this:
                       files=[{"name": image_name}], relative_path=True, show_multiview=True)
    bpy.data.lamps['Spot'].luxcore.image = bpy.data.images[image_name]
with this:
    from bpy_extras import image_utils
    img = image_utils.load_image(image_name, os.path.dirname(pattern_path))
    bpy.data.lamps['Spot'].luxcore.image = img
Running operators might require to force a scene update in some cases.
image_utils avoids this: https://docs.blender.org/api/2.79/bpy_e ... utils.html
Your script also makes some other wonky assumptions, e.g. that one of the cameras is selected. I would change this.
By the way, to do correct stereo you should use camera shift in X direction to make the camera frustums overlap exactly (currently you have some overshoot left and right if I'm not mistaken).
This is my result:
overshoot on the left and right
igall2
Post by igall2 » Wed May 09, 2018 8:43 am
Thanks B.Y.O.B,
I have replaced the code as you suggested, but still sometimes on a faster computer one of the cameras is rendered without the pattern.
It seems that this is an important point to understand.
Given multiple cameras in the scene, is it possible to render them simultaneously, by a single Blender API call?
Or, should one organize a loop by cameras? In this case, should one use viewport?
It could be that because of this misunderstanding the rendering in the uploaded script sometimes goes wrong.
I believe that once it becomes clear I can write a correct script.
Post by B.Y.O.B. » Wed May 09, 2018 3:34 pm
No you can't render simultaneously, and it is not necessary.
What I meant is that your script assumes that the camera is selected when the .blend file is opened. In my tests, I once saved the file with the spotlight selected, and the script failed.
You should access them by name, e.g. bpy.data.objects["CamLeft"], instead of bpy.context.object and assuming that it is the camera.
Then please do further tests.
If you can show that the problem is a bug in BlendLuxCore, I can help you again.
igall2
Post by igall2 » Thu May 10, 2018 10:57 am
Thanks B.Y.O.B,
I did the corrections that you have suggested.
I have done more tests. Now I have the same behavior on both computers.
One or both of the cameras are now rendered without the pattern in about 50% of the runs.
I have uploaded here the new script + Blender model:
https://drive.google.com/open?id=16f1Ow ... EgsS7SrmJL
You can download and run it in the similar way like the previous one.
Best Regards,
Igal
Post by B.Y.O.B. » Thu May 10, 2018 4:41 pm
Please test your script with Cycles as render engine.
If it works ok there but not in BlendLuxCore, I will investigate.
