Viewport shading not working as expected
Asticles
Post by Asticles » Thu Jan 11, 2018 9:49 am
Hi all
I've seen that viewport shading (Material and Texture) options are not working, they're not showing the applied image texture to the node.
Windows build.
Regards.
Salvador Ureña
Re: Viewport shading not working as expected
Post by B.Y.O.B. » Thu Jan 11, 2018 2:38 pm
Can you describe more closely what is happening and how it should look like?
Maybe with screenshots, or compare to Cycles?
I guess you mean that you plug a diffuse texture in a LuxCore node tree and it does not show up in the OpenGL viewport?
Asticles
Post by Asticles » Thu Jan 11, 2018 6:07 pm
Yes, exactly. Thanks for the answer.
Also the material viewport seems not very useful.
Salvador Ureña
Post by B.Y.O.B. » Thu Jan 11, 2018 7:12 pm
All of these are areas I have not touched at all yet.
I created an issue for later: https://github.com/LuxCoreRender/BlendLuxCore/issues/38
