Page 2 of 2
Re: LINUX Cuda (Optix) Error with BlendLuxCore 2.5beta
Posted: Sat Jan 16, 2021 8:15 am
by johannes.wilde
Update:
At least BlendLuxCore 2.4 works fine. OpenCl of course.
If i choose OpenCl in BlendLuxCore 2.5 however, it shows me the same error message as posted before using Cuda and Optix
Posted: Sat Jan 16, 2021 11:00 am
johannes.wilde wrote: ↑Sat Jan 16, 2021 8:15 am
Update:
Try to disable GPU usage for film image pipeline (i.e. use only the CPU), your error is triggered there and BlendLuxCore my force the use OpenCL for the rendering but not for the image pipeline (where it may still use CUDA).
So OpenCL should work with 2.5 too.
Posted: Sat Jan 16, 2021 12:20 pm
by johannes.wilde
That works for now with OpenCl. Thanks a lot!
There seems to be someone using Manjaro with the same GPU having the same problems:
https://www.bountysource.com/issues/922 ... uiltins-so
Posted: Sat Jan 16, 2021 10:16 pm
v440 drivers are very old, his problem may be there.
Posted: Tue Feb 09, 2021 10:05 am
by johannes.wilde
ChandraVFX postet the solution on GitHub:
Copy from Home ./config/blender/2.90/scripts/addons/BlendLuxCore/bin (place where BlenderLuxCore addon installed) all libnvrtc to /usr/lib.
example:
sudo cp libnvrtc*.* /usr/lib
Now it works!
