Update:
At least BlendLuxCore 2.4 works fine. OpenCl of course.
If i choose OpenCl in BlendLuxCore 2.5 however, it shows me the same error message as posted before using Cuda and Optix
LINUX Cuda (Optix) Error with BlendLuxCore 2.5beta
Re: LINUX Cuda (Optix) Error with BlendLuxCore 2.5beta
Try to disable GPU usage for film image pipeline (i.e. use only the CPU), your error is triggered there and BlendLuxCore my force the use OpenCL for the rendering but not for the image pipeline (where it may still use CUDA).johannes.wilde wrote: ↑Sat Jan 16, 2021 8:15 amUpdate:
So OpenCL should work with 2.5 too.
That works for now with OpenCl. Thanks a lot!
There seems to be someone using Manjaro with the same GPU having the same problems:
https://www.bountysource.com/issues/922 ... uiltins-so
v440 drivers are very old, his problem may be there.johannes.wilde wrote: ↑Sat Jan 16, 2021 12:20 pmThere seems to be someone using Manjaro with the same GPU having the same problems:
ChandraVFX postet the solution on GitHub:
Now it works!
Copy from Home ./config/blender/2.90/scripts/addons/BlendLuxCore/bin (place where BlenderLuxCore addon installed) all libnvrtc to /usr/lib.
example:
sudo cp libnvrtc*.* /usr/lib
Now it works!
