Indirect Specular pass problem
steveernst117
Post by steveernst117 » Wed Dec 30, 2020 11:18 pm
In playing around with a recent build of 2.5, I was happy to discover that there's now a caustics pass option (I had been extracting it myself for separate denoising by subtracting all other passes from the main rendered image). Unfortunately, this has revealed some problems with 2.5...
Firstly, for some inexplicable reason, the caustics pass is barely affected by the Denoise node. Even after doing a manual extraction as before, there is hardly any effect. All other passes seem to be affected as normal. I switched back over to 2.4 and everything works as expected.
Second, there seems to be a lingering problem with the Indirect Specular pass. I've got some orange glass, and in the Indirect Spec pass it's got waaay too much blue going on for some reason. This problem also occurs in 2.4.
Not sure if either of these problems are known yet, but I figured I'd say something here in case I'm just being an idiot...lol (Edit: I'm using Blender 2.91)
I'm including a test file:
luxcore_caustic_tests.blend
(770.65 KiB) Downloaded 45 times
steveernst117
Re: Indirect Specular pass problem
Post by steveernst117 » Wed Feb 03, 2021 12:18 am
Has there been any progress with these issues?
Martini
Post by Martini » Wed Feb 03, 2021 4:35 am
You can denoise the caustics pass by turning off the Pixel Filter (setting it to None). Find it under Sampling > Advanced > Filter. It's probably set to Blackman-Harris at 1.50 pixels by default. That does not work well with noise from the Metropolis sampler :D
i9 9900K @ 5000MHz | 2x Gigabyte AORUS RTX 2080 Ti Extreme Waterforce WB 11G @ 2010MHz
Z390 Aorus Pro | 32GB Kingston HyperX Predator RGB @ 4300MHz
steveernst117
Post by steveernst117 » Thu Feb 04, 2021 1:15 am
Ahhh, very interesting! Switching the filter to "None" did the trick, and I can now use the Denoise node in the compositor on the caustics pass...thanks so much!! Still very odd though, that it worked just fine in version 2.4 and not in 2.5...is it supposed to work as it is now, or is that a problem?
I don't suppose you have any insight into why the Specular Indirect pass has much more blue than it should...?
Post by Dade » Thu Feb 04, 2021 11:18 am
This: https://github.com/LuxCoreRender/LuxCore/issues/413
Post by B.Y.O.B. » Thu Feb 04, 2021 12:19 pm
Maybe pixel filtering should now be disabled in BlendLuxCore by default?
Post by Sharlybg » Thu Feb 04, 2021 12:30 pm
Any advantage of having it enable ?
Post by kintuX » Thu Feb 04, 2021 1:19 pm
Thinking it would probably be a good solution to have an on/off checker (an option, next to present filter settings)... :?:
Post by B.Y.O.B. » Thu Feb 04, 2021 1:41 pm
This can already be done by setting the pixel filter to "None".
But yes, could be made more standard with a checkbox "use filtering" and then all filter options aside from "None" in the dropdown.
Post by Dade » Thu Feb 04, 2021 2:15 pm
I was assuming it was already if OIDN was used :?:
