Hello! Maybe i do something wrong but i get very different and less realistic (in my opinion) result when i use PGI cash.
The scene is very simple. All PGI settings i left by defult.
As you see in this scene PGI gives very dark gradient on the sphere. Is it normal?
I use luxcore 2.5.
Path vs PGI
Re: Path vs PGI
When i try to attach blend file i get a messege that it is too large.
This is direct link on blend file: https://my-files.su/Save/4d2ree/blend.blend
Also i tried to render this scene on my second PC and cash works fine.
Re: Path vs PGI
my test
everything is fine
gpu cuda
everything is fine
gpu cuda
Re: Path vs PGI
Well... It is somehow depend on my system or something else... I will try to instal latest luxcore build.
Thank you.
Thank you.
Re: Path vs PGI
I solved the problem... The cause was russian username on my PC.
Re: Path vs PGI
Unfortunately, LuxCore didn't use Unicode. I don't know why, but maybe devs can explain details of it. Also textures and hdri's can't be loaded if path contains russian symbols.Endorphine wrote: ↑Sun Dec 27, 2020 11:35 am I solved the problem... The cause was russian username on my PC.
К сожалению LuxCore не использует юникод. Я не знаю почему, ведь сам блендер вполне ок с этим, может разработчики пояснят этот вопрос. Текстуры и hdri'ки тоже не грузятся, если в пути есть русские символы.
Re: Path vs PGI
As far as I know, LuxCore can: viewtopic.php?f=5&t=2197
There may be something in between to not encode the string in UTF-8.
Re: Path vs PGI
Is there any way to fix it or help with it?Dade wrote: ↑Sun Dec 27, 2020 11:49 pm As far as I know, LuxCore can: viewtopic.php?f=5&t=2197
Re: Path vs PGI
You must have some kind of error message inside the log and you can also post a test scene showing the problem.DionXein wrote: ↑Tue Dec 29, 2020 10:32 amIs there any way to fix it or help with it?Dade wrote: ↑Sun Dec 27, 2020 11:49 pm As far as I know, LuxCore can: viewtopic.php?f=5&t=2197
