Page 2 of 2
Re: strange behaviour of homogeneous scattering volume
Posted: Tue Nov 24, 2020 10:08 am
by CodeHD
lighting_freak wrote: ↑Tue Nov 24, 2020 9:39 am
On this pictures you may see that the sample plate is almost specular:
Exactly:
almost
Your choice of normal map seems to be quite a good match. Attached is your scene back with three changes:
- Clear Volume instead of Homogeneous. (The effect really comes form the surface alone. You can add some absorption color but there is no volume scattering in your material)
- Increased the normalmap's Height setting a bit.
- Switched to Path + GPU. No need for BiDir here.
Below is the rendering result. A little more Height will probably better match your picture.
Posted: Tue Nov 24, 2020 6:33 pm
by CodeHD
Little addendum: I realised the sample is a bit darker than the background because I left the path depth at the default value of 6, so that a small Fresnel-reflection part is not traced. (Gamma correction then amplifies it.)
So just increase the total and specular path depth a little and the result will be brighter, as it should be without volume absorption or other losses.
Posted: Thu Nov 26, 2020 8:26 pm
by lighting_freak
Hello all,
finally the sample part that should use the DF23 material. I hope the download-link works:
https://www.dropbox.com/t/4OvpV1lyUnVKTr5R
Material definiton in that sample is different, compared to the one that we made during the last days.
I continue the investigations on the material - the goal is still a valid volume definition. The DF23 material is a diffuse one, 100% sure. My current target procedure is to find a volume & surface setting that fits the visual appearance (somehow in daylight and lit through condition) to the real sample. This volume will find it's way into that model and for the surfaces I have to find a new way.
Do you have any idea how to model a VDI grain structure that creates a special light pattern while it shines through the surface?
I'll keep you updated for the sample plaque progress.
BR
Posted: Thu Nov 26, 2020 8:50 pm
by CodeHD
Looking back at the data sheets, you might be right that there should be a diffuse volume component to the DF range, however it really looks small if any in you images... Do you have any more explicit data on what DF"23" and "8N" actually mean? I didn't find anything on their website.
What is a "VDI" grain structure? I don't know that abbreviation.
Posted: Fri Nov 27, 2020 7:07 am
by lighting_freak
HI,
sure I can try to describe the meaning:
Let's start with "8N" - it is the clear basic PMMA material.
The "DF_XX" is the density of light diffusing elements within this basic acrylic. The higher this number the more diffuse the volume is.
There are some images that show some key facts to the pure (not satiniced, but polished surface) material (sorry that they are in German):
This is how it works:
This is how diffusion is defined and measured:
They measure the angle that shows a light intensity fall-off to 50% of its highest intensity at normal view.
The diffusion angle is given as "half width half max - HWHM".
This are the results for vayiing DF materials:
I hope this helps to understand the volume.
The VDI is a description of how to make a reproduceable grained structure.
It's a definition of a surface roughness.
For my test setup I'd like to have the DF23 volume combined with the VDI 36 surface.
With best regards
Posted: Fri Nov 27, 2020 12:57 pm
by CodeHD
Ok thanks for the additional info. Really don't know why I resented the idea that VDI would be the organisation in this context
You would certainly have to play with the anisotropy of the volume scattering to get this effect. I could imagine one could even recreate this test setup, and write a render-script to find good values. Unfortunately, that still needs an additional info: the thickness of the material for which this material property is defined.
Regarding the VDI grain: That seems to define a certain integral of the surface shape (I have not looked up all details), which can surely be computed for any surface. An accurate representation of your material will probably require more knowledge though, since multiple shapes coudl fulfill the same roughness criteria. How big the impact on your case would really be, again no idea...
Posted: Mon Nov 30, 2020 2:06 pm
by lighting_freak
Hello all,
CodeHD wrote: ↑Fri Nov 27, 2020 12:57 pm
I don't believe that we have to use anisotrophy settings. The material is a molding compound, no directional dependency is expected if you do some real parts from it.
I forgot to mention that the scattering cone that is mentioned in the pictures above is measured at a 3mm thickness. I could get it for other thicknesses as well.
I can measure the scattering cone of the sample plaque, but how can I transfer this information into luxcorerender (keywords BRDF/BSDF/BTDF)?
You're right, this defintion is purely a mechanical one and different shapes do really create different light scattering... I know that this will require deeper investigation afterwards but at first a valid way to insert those data would be nice.
This is my current status:
Normal view:
- still not blurry enough
Slight tilted view for reflection:
- good specular reflex
Posted: Thu Dec 03, 2020 2:25 pm
by CodeHD
lighting_freak wrote: ↑Mon Nov 30, 2020 2:06 pm
If you want to model the ~20 degrees diffusion angles, then you do. With anisotropy = 0, scattering is equal in all directions and you have no HWHM by definition.
One thickness should be enough.
Your full material is a combination of a volumetric scattering and a rough or "satinated" surface.
As said before, I would start with finding good values for the scattering scale and anisotropy. Note that for a good comparison with a real material, you should minimize other differences. Most importantly, compare it with a sample that has a polished surface, not rough.
Finding the right surface model may be a bit more tricky. For on-axis, the trick with anormal map might give you good results, but I fear at large angles you may see the influence from micorfacet-multiscattering. I'm not sure if any LuxCore matieral at the moment supports that.
