Very long wait for caches enabled
nigma46
Re: Very long wait for caches enabled
Post by nigma46 » Thu Nov 12, 2020 12:10 am
sure.
ground truth (no cache, PT only)
Post by B.Y.O.B. » Thu Nov 12, 2020 8:59 am
You can try to raise the brute force radius scale, but this will lower rendering performance because the cache will be used less (over the whole image).
Or you could disable cache usage for the floor (in the material output node advanced settings).
nigma46
Post by nigma46 » Thu Nov 12, 2020 9:02 am
Brilliant idea! Thanks.
Post by Dade » Thu Nov 12, 2020 9:37 am
Do walls have thickness ?
nigma46
Post by nigma46 » Thu Nov 12, 2020 11:17 am
no, they don't actually. Is this what causes it?
Post by Dade » Thu Nov 12, 2020 11:38 am
Likely, you can have light leaks due to numerical precision (or too large cache entry conditions like normal angle, etc.) in that case.
Post by B.Y.O.B. » Thu Nov 12, 2020 11:44 am
Note that you don't have to add a solidify modifier to the walls if that generates too many new polies, you can also just put boxes behind the walls to block the light.
nigma46
Post by nigma46 » Fri Nov 13, 2020 12:36 am
After trying blocking volumes, thickening the floor, setting face smoothing to flat.. in the end what resolved it was changing the wall geometry so that part of it did not intersect with the floor geometry. Intresting to know. Will avoid this in future.
