question
Re: question
Post by Dade » Thu Oct 22, 2020 10:56 am
Dade wrote:
Thu Oct 22, 2020 10:17 am
B.Y.O.B. wrote:
Wed Oct 21, 2020 11:54 am
Curious. That bright rectangle on the ceiling even shows up when rendered in Blender after importing the PLYs, with completely different lighting.
And it even shows on a fresh plane mesh that is slightly rotated, so it's probably not related to a problem in the ceiling mesh.
It is also BIDIRCPU only problem (inside eye pass) while the scene works fine with PATH(CPU or GPU).
I should have fixed the problem. This was before:
and this after the fix:
Re: question
Post by daros » Thu Oct 22, 2020 10:58 am
Yessss! Grande!
Re: question
Post by daros » Thu Oct 22, 2020 11:07 am
And regarding the previously postes issue with 100% white materials? And which is eventually the maximum white point Luxcore handels?
Re: question
Post by daros » Thu Oct 22, 2020 11:26 am
Sorry one more question. The attached scene, which was created using SDK, renders differently wen rendered on linux using SDK as rendered on windows using standalone 2.4. the brighter one is with SDK under linux and the darker one is using standalone under windows.
4.zip
(399.21 KiB) Downloaded 16 times
Re: question
Post by Dade » Thu Oct 22, 2020 11:30 am
I'm not sure to understand how the rendering was done. Have you set all materials to "Matte" with a value of "1.0 , 1.0, 1.0" ?
In that case, the result looks correct, light is perfectly reflected at any bounce: it is a very unrealistic scenario, light is always partially adsorbed on a bounce (White is usually something like "0.7, 0.7, 0.7").
Re: question
Post by daros » Thu Oct 22, 2020 11:33 am
Ohhh... 0.7! i was guessing 0.9 or something like that. Good to know!, thanks.
Re: question
Post by daros » Thu Oct 22, 2020 11:44 am
so even every texture has to be darkened by 30%?
Re: question
Post by B.Y.O.B. » Thu Oct 22, 2020 11:55 am
When creating textures, the same principle applies. So a texture that has a patch of "pure white" should have values around (0.7, 0.7, 0.7) in that area.
Re: question
Post by Dade » Thu Oct 22, 2020 11:58 am
Yes if the texture has values normalized between [0.0, 1.0] (often, if the texture source is a photo, it is already scaled and it is not normalized). You can use a math node in LuxCore scene to scale the original texture.
Re: question
Post by daros » Thu Oct 22, 2020 2:16 pm
Thanks a lod Dade.
Light distribution ipmroved a lot!
This is a 70 seconds test using oidn.
