Epsilon
Min:
0.05
Max:
0.5
Result...
PS
Also, w/ this file I noticed that whenever I made a larger/broader Epsilon change, CUDA recompiled from scratch.
Didn't do it systematically, but at random... if anyone is willing to check.
Another thing is an error report (using mentioned values):
[LuxCore][7163.250] [GeForce GTX 1070 CUDAIntersect] Memory used for hardware image pipeline: 14175Kbytes
File "C:\Users\309\AppData\Roaming\Blender Foundation\Blender\2.83\scripts\addons\BlendLuxCore\engine\base.py", line 87, in render_final
final.render(self, depsgraph)
File "C:\Users\309\AppData\Roaming\Blender Foundation\Blender\2.83\scripts\addons\BlendLuxCore\engine\final.py", line 54, in render
print('[Engine/Final] Finished rendering layer "%s"' % layer.name)
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xb0 in position 0: invalid start byte
ERROR: 'utf-8' codec can't decode byte 0xb0 in position 0: invalid start byte
File "C:\Users\309\AppData\Roaming\Blender Foundation\Blender\2.83\scripts\addons\Stop-motion-OBJ\stop_motion_obj.py", line 95, in renderCancelHandler
renderStopped()
File "C:\Users\309\AppData\Roaming\Blender Foundation\Blender\2.83\scripts\addons\Stop-motion-OBJ\stop_motion_obj.py", line 100, in renderStopped
bpy.data.scenes["Scene"].render.use_lock_interface = storedUseLockInterface
KeyError: 'bpy_prop_collection[key]: key "Scene" not found'
Epsilon Max. 1.0, it doesn't render anymore and returns this
error:
[LuxRays][7581.156] [BVHKernel] CUDA program compilation error:
epsilon_funcs.cl(32): error #18: expected a ")"
epsilon_funcs.cl(32): error #308: more than one instance of overloaded function "clamp" matches the argument list:
function "clamp(float, float, float)"
function "clamp(int, int, int)"
argument types are: (const float, float, int)
bvh.cl(144): warning #191-D: type qualifier is meaningless on cast type
2 errors detected in the compilation of "BVHKernel".
File "C:\Users\309\AppData\Roaming\Blender Foundation\Blender\2.83\scripts\addons\BlendLuxCore\engine\final.py", line 48, in render
_render_layer(engine, depsgraph, statistics, layer)
File "C:\Users\309\AppData\Roaming\Blender Foundation\Blender\2.83\scripts\addons\BlendLuxCore\engine\final.py", line 60, in _render_layer
engine.session = engine.exporter.create_session(depsgraph, engine=engine, view_layer=view_layer)
File "C:\Users\309\AppData\Roaming\Blender Foundation\Blender\2.83\scripts\addons\BlendLuxCore\export\__init__.py", line 215, in create_session
pyluxcore.KernelCacheFill(config_props_copy)
RuntimeError: BVHKernel CUDA program compilation error
ERROR: BVHKernel CUDA program compilation error
renderStopped()
Info: Compiling CUDA kernels (just once, takes a few minutes)
GPU Limit...
PS.
@Dez!
I would advise to retopo/remesh your geo to prevent such headaches in the future. Elongated (long edged) polys are known to cause shading issues.
Keep up the good work.
PPS
- Epsilon Max 0.1 works fine (default)
- CUDA recompiles from scratch whenever Epsilon Max. value is changed
- full log attached
