Guys, why I continue getting this message (and compilation) if it was done once? I think this is the 6th time it happens...
CUDA Kernels
- Leandro Oliveira
Re: CUDA Kernels
Are you using a utility that clears out your temporary files on Windows (CCleaner etc...?)
%temp%\luxcorerender.org\ocl_kernel_cache contains the OpenCL kernel, if that gets wiped it needs to recompile it.
- Leandro Oliveira
Re: CUDA Kernels
Zeealpal, yes, I use CCleaner. So, that´s the cause...Thanks, man! I´ll make a copy of it, to prevent recompiling.
Thank you, very much!
