Different light behavior comparing Preview to Final Render
Leandro Oliveira
Post by Leandro Oliveira » Fri Sep 25, 2020 9:58 pm
Hi everybody.
Why this is happen? Lights in preview render are so different from final render.
Preview
Final
Re: Different light behavior comparing Preview to Final Render
Post by Sharlybg » Fri Sep 25, 2020 11:37 pm
Maybe a light is off rendered for final. But can be solething else. We do need the actual scene ( simple version of the scene).
Leandro Oliveira
Post by Leandro Oliveira » Fri Sep 25, 2020 11:50 pm
Sharly, are caches view dependent? Because I tried to generate caches from this view (original caches were computed from the living room) and it returned a different look.
I´ll send you the scene.
Add cache location
Leandro Oliveira
Post by Leandro Oliveira » Fri Sep 25, 2020 11:58 pm
Shaly, I´ve sent you the scene. See your private messages.
Thanks.
Post by Dade » Sat Sep 26, 2020 10:41 am
During viewport rendering, caches are disabled (in order to avoid pre-processing time) and the default number of light bounces is reduced (to increase rendering speed). This may produce a darker rendering if you have a lot of indirect light.
This may explain your problem.
Cache entries are view independent but the number and the position of cache entries is based on the camera used to create the cache.
The very first step of cache creation is to fire "visibility particles" and mark places where they bounce (4 max. bounces is the default setting). The cache entries are create there and only there.
If you have a building with 100 rooms, the cache will be created for the room where the camera is and for near rooms reachable in 4 bounces. Far you are from the original room and less likely the surfaces have cache entries.
So if you are doing an animation inside the same room, you can reuse the cache, if you move across many rooms, you need to update the cache.
Post by B.Y.O.B. » Sat Sep 26, 2020 10:45 am
Not in the Blender addon, as far as I know.
Leandro Oliveira
Post by Leandro Oliveira » Sat Sep 26, 2020 1:24 pm
Dade, that´s it! I have to update cache, because I have other rooms. Thanks a lot!
I forgot to mention that I´m using Blender 2.83.6 and Lux 2.4.
And about BYOB observation?
Leandro Oliveira
Post by Leandro Oliveira » Sun Sep 27, 2020 2:48 am
Another question: light rays emitted from mesh lights are considered indirect light?
Post by Dade » Sun Sep 27, 2020 11:56 am
Only after > 1 bounces.
