Math Node CPU/GPU Bug?
Posted: Mon Sep 21, 2020 8:03 pm
by HoppyHopp
Hey,
i played arround mixing a normal and bump map. When i use "Add" there is a big difference between CPU and GPU.
It is the same with "Subtract" but no problem when i use "Mix", "Multiplay" or "Divide"
CPU
GPU
Nodes
Re: Math Node CPU/GPU Bug?
Posted: Mon Sep 21, 2020 10:19 pm
What Lux version are you using ? Can you post a simple test scene with a cube and your material definition ?
Posted: Thu Oct 08, 2020 3:00 pm
by HoppyHopp
Here i have another missmatch between CPU and GPU.
CPU
GPU
Nodes
I attached the blend-file
Posted: Fri Oct 09, 2020 9:12 pm
by HoppyHopp
I tried now 2.4 and latest 2.5 version. Still the sam difference between cpu and gpu.
Can someone reproduce the problem with my file and can solve the problem? :)
Posted: Mon Oct 19, 2020 8:27 am
by HoppyHopp
Nobody can help? :(
Posted: Mon Oct 19, 2020 9:01 am
by Dez!
my video driver breaks down.
the system goes into a black screen.
checked three times. only reset helped three times
Posted: Tue Oct 20, 2020 4:31 pm
HoppyHopp wrote: Mon Oct 19, 2020 8:27 am Nobody can help? :(
Forum_Spiral_cpu
Forum_Spiral_cpu
Forum_Spiral_gpu
Forum_Spiral_gpu
Similar result like yours. :roll:
Posted: Wed Oct 21, 2020 9:29 am
by HoppyHopp
FarbigeWelt wrote: Tue Oct 20, 2020 4:31 pm
So how do we fix it? I mean there shouldn't be a difference, right?
Posted: Wed Oct 21, 2020 3:42 pm
HoppyHopp wrote: Wed Oct 21, 2020 9:29 am
... I mean there shouldn't be a difference, right?
Correct. Some one should open an Issue in Github.
