Math Node CPU/GPU Bug?
HoppyHopp
Post by HoppyHopp » Mon Sep 21, 2020 8:03 pm
Hey,
i played arround mixing a normal and bump map. When i use "Add" there is a big difference between CPU and GPU.
It is the same with "Subtract" but no problem when i use "Mix", "Multiplay" or "Divide"
CPU
GPU
Nodes
Re: Math Node CPU/GPU Bug?
Post by Dade » Mon Sep 21, 2020 10:19 pm
What Lux version are you using ? Can you post a simple test scene with a cube and your material definition ?
HoppyHopp
Post by HoppyHopp » Thu Oct 08, 2020 3:00 pm
Here i have another missmatch between CPU and GPU.
CPU
GPU
Nodes
I attached the blend-file
Lightbox1.blend
(2.08 MiB) Downloaded 43 times
HoppyHopp
Post by HoppyHopp » Fri Oct 09, 2020 9:12 pm
I tried now 2.4 and latest 2.5 version. Still the sam difference between cpu and gpu.
Can someone reproduce the problem with my file and can solve the problem? :)
HoppyHopp
Post by HoppyHopp » Mon Oct 19, 2020 8:27 am
Nobody can help? :(
Dez!
Post by Dez! » Mon Oct 19, 2020 9:01 am
my video driver breaks down.
the system goes into a black screen.
checked three times. only reset helped three times
Post by FarbigeWelt » Tue Oct 20, 2020 4:31 pm
Nobody can help? :(
Forum_Spiral_cpu
Forum_Spiral_cpu
Forum_Spiral_gpu
Forum_Spiral_gpu
Similar result like yours. :roll:
HoppyHopp
Post by HoppyHopp » Wed Oct 21, 2020 9:29 am
So how do we fix it? I mean there shouldn't be a difference, right?
Post by FarbigeWelt » Wed Oct 21, 2020 3:42 pm
... I mean there shouldn't be a difference, right?
Correct. Some one should open an Issue in Github.
