Hey,
i played arround mixing a normal and bump map. When i use "Add" there is a big difference between CPU and GPU.
It is the same with "Subtract" but no problem when i use "Mix", "Multiplay" or "Divide"
CPU
GPU
Nodes
Math Node CPU/GPU Bug?
Re: Math Node CPU/GPU Bug?
Here i have another missmatch between CPU and GPU.
CPU
GPU
Nodes
I attached the blend-file
CPU
GPU
Nodes
- Attachments
- Lightbox1.blend
- (2.08 MiB) Downloaded 172 times
I tried now 2.4 and latest 2.5 version. Still the sam difference between cpu and gpu.
Can someone reproduce the problem with my file and can solve the problem?
Nobody can help?
my video driver breaks down.
the system goes into a black screen.
checked three times. only reset helped three times
- FarbigeWelt
- Contact:
MacBook Air with M1
MacBook Air with M1
So how do we fix it? I mean there shouldn't be a difference, right?
- FarbigeWelt
- Contact:
Correct. Some one should open an Issue in Github.
MacBook Air with M1
MacBook Air with M1
