transparent material + wood artifacts
Posted: Wed Sep 16, 2020 7:21 am
by zooropa
Hi. I am dealing with a new scene and I am getting some strange artifacts on some of my meshes.
I believe it has to do with the intersection between the acrylic glass and the wood. I am not sure if this should be the expected result when this happens.
Unfortunately the render looks better when the meshes intersect, I would like to keep it like that.
I am using lux 2.5
- with the glass
- without the glass
Re: transparent material + wood artifacts
Posted: Wed Sep 16, 2020 9:34 am
Posted: Wed Sep 16, 2020 9:37 am
by zooropa
Thank you, can i ask how did you solve this. I checked the link, but I need to render within Blender.
Posted: Wed Sep 16, 2020 9:44 am
zooropa wrote: ↑Wed Sep 16, 2020 9:37 am
Try to delete and rebuild the wrong face hand hope it will not happen elsewhere. It is a bug and Devs will look into it.
Posted: Wed Sep 16, 2020 10:03 am
by zooropa
Sharlybg wrote: ↑Wed Sep 16, 2020 9:44 am
Thank you ! I I just hope it does not affect my uv maps..It took me a long time to set it .
Posted: Wed Sep 16, 2020 10:07 am
It may be not the same problem, Zooropa, just try to rise a little the glass top: if the surface of the glass and wood one are too near, due to limited floating point 32bit precision, LuxCore may detect the intersection with the glass plane and not with the wood surface (so seeing inside the closed wood box: just all black).
Posted: Wed Sep 16, 2020 12:42 pm
by Leandro Oliveira
I would say the same as Dade. Objects with transparent materials, can´t touch other surface, because renderer don´t know what face it should renders.
Posted: Thu Sep 17, 2020 5:54 am
by zooropa
Leandro Oliveira wrote: ↑Wed Sep 16, 2020 12:42 pm
Thank you. I was doing like in cycles, where they worked. Now I know, after moving a bit the acrylic glass I stop having those black artifacts.
Posted: Thu Sep 24, 2020 12:57 am
by Leandro Oliveira
