Unable to Render on a MAC
JacquesKCT
Post by JacquesKCT » Tue Sep 15, 2020 2:47 pm
Attempting to Render gives the following error codes. Please help.
Re: Unable to Render on a MAC
Post by B.Y.O.B. » Tue Sep 15, 2020 4:25 pm
JacquesKCT
Post by JacquesKCT » Wed Sep 16, 2020 8:30 am
Your vague reply I think points to testing Luxmark. I did this and there wasn't an issue running the benchmarks (all combinations). I then retried running Blender 2.83.6 and rendering out a still using LuxCore and the attached errors were reported. I think the OpenCL is fine because the LuxMark tests were run without a problem, so is the problem then with the Mac OSX release of LuxCoreRender?
Post by Dade » Wed Sep 16, 2020 9:37 am
Same question of other thread: what LuxCore version are you using ?
Does it happen with an automatic build of the under development v2.5 (viewtopic.php?f=9&t=736) ?
JacquesKCT
Post by JacquesKCT » Wed Sep 16, 2020 10:12 am
Have Tried both the 2.4 version as offered for download on the LuxCore website and 2.5 builds.
The initial problem was with the published 2.4 version.
So I tried the experimental 2.5 build but it won't / can't run because the developer hasn't signed the pyluxcore file so MacOS x sees it as malicious.
JacquesKCT
Post by JacquesKCT » Fri Sep 18, 2020 9:42 am
So the Mac version is broken?
Post by Dade » Fri Sep 18, 2020 11:42 am
I have no idea, I don't have a Mac but v2.4 is working for other people so I assume it is a problem with your installation.
