Page 1 of 2
weighted normal modifier not working
Posted: Sat Sep 12, 2020 3:04 pm
by zooropa
Hi. I am using a weighted normal modifier in my mesh in order to avoid the broken reflections of the mesh. I can see it works in the viewport, but not in the render. I am using lux 2.5 If this is not supported I will proceed to model the mesh only with quads and subdivision modifier. I was trying to avoid complex topology since its just a flat plane with thickness and bevel edges.
Thank you
Re: weighted normal modifier not working
Posted: Sat Sep 12, 2020 3:22 pm
I don't know about weighted normal modifier but sharp edge modifier should do the trick.
Posted: Sat Sep 12, 2020 3:32 pm
by PetrT
maybe edge split can help
Posted: Sat Sep 12, 2020 3:33 pm
by zooropa
There is no sharp edge modifier
Posted: Sat Sep 12, 2020 4:04 pm
by zooropa
I think its cause luxcore does not take in count that modifier maybe
Posted: Sat Sep 12, 2020 4:09 pm
Talking about this one.
PetrT wrote: ↑Sat Sep 12, 2020 3:32 pm
Posted: Sat Sep 12, 2020 4:28 pm
by zooropa
Not working, I happily share my file if you like to
Posted: Sat Sep 12, 2020 5:45 pm
What Blender version are you using? Custom normals are not yet supported in Blender 2.90.
Posted: Sat Sep 12, 2020 6:44 pm
by zooropa
I am using 2.9 so actually this artifact will be visible also in cycles...
Posted: Sun Sep 13, 2020 8:09 am
by zooropa
B.Y.O.B. wrote: ↑Sat Sep 12, 2020 5:45 pm
Do you mean luxcore and blender 2.9 ? Cause I tried and works in cycles.
