weighted normal modifier not working
zooropa
Post by zooropa »
Hi. I am using a weighted normal modifier in my mesh in order to avoid the broken reflections of the mesh. I can see it works in the viewport, but not in the render. I am using lux 2.5 If this is not supported I will proceed to model the mesh only with quads and subdivision modifier. I was trying to avoid complex topology since its just a flat plane with thickness and bevel edges.
Thank you
Re: weighted normal modifier not working
I don't know about weighted normal modifier but sharp edge modifier should do the trick.
PetrT
Post by PetrT »
maybe edge split can help
zooropa
Post by zooropa »
There is no sharp edge modifier
zooropa
Post by zooropa »
I think its cause luxcore does not take in count that modifier maybe
Talking about this one.
PetrT wrote: Sat Sep 12, 2020 3:32 pm maybe edge split can help
zooropa
Post by zooropa »
Not working, I happily share my file if you like to
What Blender version are you using? Custom normals are not yet supported in Blender 2.90.
zooropa
Post by zooropa »
I am using 2.9 so actually this artifact will be visible also in cycles...
zooropa
Post by zooropa »
B.Y.O.B. wrote: Sat Sep 12, 2020 5:45 pm What Blender version are you using? Custom normals are not yet supported in Blender 2.90.
Do you mean luxcore and blender 2.9 ? Cause I tried and works in cycles.
