luxcore nishita sky texture?
zooropa
Post by zooropa » Sat Sep 05, 2020 3:19 pm
HI. Just a fast question. Does luxcore works with the new Nishita node in Blender?
Thank you
Re: luxcore nishita sky texture?
Post by Dade » Sat Sep 05, 2020 3:25 pm
No, we are using the Hosek/Wilkie model (from 2012). Nishita is a very old model (form 1993), I doubt it is worth supporting it.
zooropa
Post by zooropa » Sun Sep 06, 2020 9:16 am
Thank you for the fast answer. Did not know Nishita was an old solution. Is it possible to download Lux 2.5? Does it run Blender 2.9?
Post by Dade » Sun Sep 06, 2020 10:30 am
Automatic builds of the under development v2.5 are available here: viewtopic.php?f=9&t=736
zooropa
Post by zooropa » Sun Sep 06, 2020 10:36 am
Thanks a lot, I will give it a try for my new furniture. I am trying to do a simple, but realistic scene.
Maybe this the time to try for third time LuxCore :)
Thank you
Post by CodeHD » Thu Dec 03, 2020 11:38 am
Since this question keeps coming up (and will keep coming up), I just want to leave some more info here:
Cycles seems to not use the old Nishita model directly, but an extended model based on it. I found a bit more detailed description here:
https://docs.google.com/document/d/1gQt ... 36m08/edit
